GT Silly Car MOT September 2013
Celica 3SGE ST202 2.0 GT For Sale I have had this for just under a year. I fancy a change
Best of both worlds with facelift bumper and prefacelift engine so there is no egr rubbish so the standard power is 175bhp were most are 168bhp.
The ACIS works as it should and kicks in around 5500rpm. Car is running 186BHP and still gets 32mpg easy and up to 40 on a good run.
Mods
Wrapped manifold
Decat
Powerflow cat-back
Power deck spacer
Red stuff pads all round with Mtec grooved discs
K&N panel filter
Alloy racing radiator
Silicone hoses in blue
Grounding Kit
Refubed Wheels very clean
4 PROXES T1-R week old
HID 35w 4300k so not to blue
HID wiring harness
Two upper front strut braces and a rear upper brace
JDM number plate console
JDM spec gearknob
Carbon wrapped trims
Other new bits
@128286 I got the car
@128374 New Thermostat
@128461 Oil and filter change
@129158 Air and Fuel filter replaced
@130665 Air box changed to standard one and exhaust manifold has been wrapped
@130740 Rear drop links and anti roll bar bushes replaced
@131455 New brakes fitted redstuff pads with Mtec grooved discs
@131689 Front drop links changed
@131880 Power flow exhaust fitted
@132709 Oil and filter change
@134181 Alloy racing rad and silicon pipes fitted along with a new K&N panel filter.
@134969 CV Joints and front anti roll bar bushes replaced.
@135550 Four new tyres PROXES T1-R & wheel alignment front and rear.
@136612 NGK Laser Platinum plugs fitted
@137931 New O/S/F Wheel bearing and a fresh MOT
@138974 Oil and filter change
@139865 Front brake calipers serviced Battery topped up and removed the big resonator box in the wing.
@140058 Power deck spacer and new gaskets fitted.
@140828 40mm suspension drop with new rear drop links.
Am not in a rush to swap/sell up and am still using the car every day offers around £1000
[Image: IMAG0316.jpg]
[Image: IMAG0326_zps4db86dd8.jpg]
[Image: IMAG0324_zps2cce7a37.jpg]
[Image: IMAG0437.jpg]
[Image: IMAG0690.jpg]
[Image: IMAG0691.jpg]
[Image: IMAG0695.jpg]
[Image: IMAG0511.jpg]
[Image: IMAG0448.jpg]
[Image: IMAG0696.jpg]
[Image: IMG_7620.jpg]
[Image: IMAG0466.jpg]
[Image: IMAG0460.jpg]
[Image: IMAG0463.jpg]
[Image: IMAG0781_zpsc1c9d74e.jpg]
[Image: IMAG0600.jpg]
[Image: IMAG0602.jpg]
[Image: IMG_4598_zps346c1bd6.jpg]
[Image: IMG_4594_zps62958730.jpg]
[Image: IMG_4597_zps1f1c7b59.jpg]
More to come
[Image: IMG_3589_zpsa4db9142.jpg]
[Image: IMG_3593_zps408fb5cd.jpg]
[Image: IMAG0441.jpg]
[Image: IMAG0487.jpg]
[Image: DSC_0094_zps071b38f9.jpg]
[Image: IMAG0474-1.jpg]
[Image: IMG_3257.jpg]
[Image: 331607_10152010113815335_1182703831_o.jpg]
[Image: IMAG04901.jpg]
http://www.youtube.com/watch?v=PrTv4hkEmeI
list=UUJWiMi3L8_VFRjsAnw_DQ0w&index=15
http://www.youtube.com/watch?v=pnNacUIrw...0w&index=5
More videos and photos if needed
I have been for a ride in this and its pretty epic! The grip is awesome and it pulls brilliantly. Has been well looked after!
