PH2 rad->PH1 rad
Can I change my radiator for a phase one type by just changing the bottom hose? Or will it not fit in the phase 2 slam panel etc?
Want to get this header tank out of the way, it's ruining my plans! Dodgy
GT2052s DTurbo
OEM+ HDI Estate
Project thread
As far I can I tell the pipes run different.
Pipes are different. Need to swap the rad.
I am wanting to do this. I brought the radiator and a new bottom pipe but then realised I needed another so I had to put the phase 2 one back on.
The phase one only has one pipe that goes around to the water distributor on the back of the block. I have a silicon end cap to block that. So you'll need one of them or the phase one distributor.
The other thing you'l need is the phase 1 pipe which has the bleed point in it, because the point it attaches to the radiator is lower down so the pipes longer.
[Image: 20120704_212316.jpg]
Hmm, sounds like too much effort really, if it was straight swap with maybe just 1 pipe different then it would be worth it.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
It's only the one pipe you need to get, and the cap. How much do you want the extra room?
Not that much, would have just been nice to use it for air filter routing. I am going to use a different route for the filter now anyway.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
ricky if you want to do it i am breaking a white ph one dt would have everything you need nc a nissens ally rad Smile
If Ricky doesn't want any of it then ill be interested in a couple of little bits. I'm in no rush though so if Ricky wants them no worries.
Will drop you a PM ash Smile
GT2052s DTurbo
OEM+ HDI Estate
Project thread
