Threads: 27
20
@ ruan I think we need to have a chat! I run an electronics manufacturing company with my old man, £350k pick and place, board design, lead free wave solder, make stuff for mod, lotus, formula 1 teams pm me your number
Threads: 541
124
Yeah, why not lol.
Think im gonna wire a vac over ride so i can open the vanes on the motorway, just need it set so theyer slightly open so its making a little boost for efficiency
Threads: 202
58
Manual VNT control?
Make sure you always have a passenger who knows what to do?
Sounds like a good idea!
Threads: 591
54
Load sensing output from the alternator...into fancy cap and converter
then use a 12v actuator from another application?!
I know I am thick...but could it not be that simple?!
Threads: 6
Car Model/Spec: 406 2.1td
Very good Ruan, I see you're the first driver in this way in the XUD vnt. . . I'm also on the way, but now I have very little time or money for research, but if I have the arduino, 2 n75, plate, transistors. . . and loaded the program and e visusalizado the menu. I have to solder the components to the board, but was waiting to be sure of his mount. By the way, you have the LCD? I tried it and is very comfortable. I need is map sensor, you've got? one of 3bar and 2bar absolute reading?
I would like your help for installation as the instructions, do not quite understand, and I do not speak English, only Spanish. . . and it sucks always use translators. Spain is here in this lonely prepare and less XUD engines. . . Only with remap tdi's. . . .
Greetings and look forward to the new GTB. . .
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
(08-01-2013, 01:00 PM)n0v0s Wrote: http://www.ebay.co.uk/itm/mercedes-c-cla...4ac01a7572
Gt1852v
good luck adapting the hot side on that - the merc turbos have the gay'est hotside setup ever...
Just to chuck my 2p in; in regards with the "free software" - Ruan, has a point, decent software as he is more of a specialist than most on this forum, thus has the knowledge capable for putting it into practice; personally i wouldn't touch the software as i'm pretty useless with electrics.
There are other means to controlling VNT's besides electrics and software and i think Max (and myself) are pretty much there, mechanically at least, and if we were to sit down a properly put pen to paper we'd nail it..
Be inetersting to see some more VNT's being put into practice this summer
Phaes 1 GTI 6 - Onyx Black
Threads: 6
Well, like everything else, is get to learn, much better if someone helps you, insistence is the key to many advances. I already vimuchos montages vnt control mechanics, but I do not seem reliable when you have high pressure, I think you mucos pressure spikes and are dangerous in the long run in high performance engines. . .
I see safer electronic control and an LCD where you visualize all pressures and temperatures rpm. . . I guess everyone likes lol
