Threads: 14
Car Model/Spec: 306 TD 1.9
Hello,
I am looking at servicing my car and was wondering what oil people recommend as I have read and seen various different oils been suggested and was wondering what other people use. Where do people buy there service items from?
Also does anyone have the Aux Belt part no.?
Thanks
Dan
Threads: 226
24
Car Model/Spec: A3 TDi
28-12-2012, 12:28 PM
(This post was last modified: 28-12-2012, 12:29 PM by Tom.)
Opie oils.
5w/40
Threads: 14
Cheers Tom. Any particular brand of the oil?
Threads: 48
Car Model/Spec: PH1 306 GTDTurbo
I tend to use Castrol Edge Oil in mine.
There will be quiet a choice on Aux Belt part numbers, depends if it has Air Con etc.
Give your reg number to your local motor factors and they will be able to tell you which one you need.
Threads: 110
20
Threads: 541
124
I usually get my oil and filters from pug, Total Quartz 7000 10w40 as its whats recommended and its less than £20 a bottle. The pug filters are alot better quality than pattern parts and TBH if your gonna get pattern parts you might as well borrow a halfords trade card as an oil filter is about £2
Some people put 5w40 in these to help cold start but many have had issues with seals starting leaking when they make the switch.
Threads: 141
35
oil choice is really down to how you drive it/power etc
the first number refers to the protection/thickness when cold while the number after the w refers to hot protection/thickness
running 5w40 means the oil is thin when cold offering better protection from startup.
peugeot recommend a good quality 10w40 but it all depends on our budget really, if your running a very high power xud you'd want to spend alot on really good oil like gulf race 10w40 oil, or miller 10w40 race oil but it costs :/
a good compromise is mobil 1 super 2000 or castrol, decent oil but without the race oil price tag.
as for service parts its easiest just to go to somewhere like unipart, give them your reg and let them sort it out, then if they give you the wrong part its just a matter of taking it back and swapping it
Threads: 14
Thanks for that Dum-Dum. Will I be able to walk into any peugeot dealer and get the parts or are they order only?
Threads: 226
24
Gulf is good stuff. And obviously whatever peugeot recommends would be sufficient.
Threads: 48
28-12-2012, 02:07 PM
(This post was last modified: 28-12-2012, 02:25 PM by Marcus1991.)
Yes you can walk in. Most Peugeot dealers have regular service parts in stock, if not they can usually get them in within a day or two.
Threads: 541
124
Yeah youll be able to walk into any dealer and theyll have it all in stock. Most do a 10% trade discount that you can try and blag. Also if your near a Tomo parts they do genuine pug parts too.
If you want to see the difference in quality between pug filters and pattern ones just go and buy both and youll see the difference. I cant believe some people spend £50 on oil only to put on a cheap filter that wont filter properly and dosent have a decent non return valve.
Threads: 29
10w40 will suffice.
Non aircon aux belt is 6pk1105 I think.
Threads: 14
Cheers KrisB, the car has AC though I will go to the local motor factors and find out which belt I need.
Threads: 14
Morning all. Just another quick question. Can anyone tell me what size tool I need for removing the sump plug.
Cheers
Threads: 36
18
Car Model/Spec: DT
(05-01-2013, 11:05 AM)DanWY Wrote: Morning all. Just another quick question. Can anyone tell me what size tool I need for removing the sump plug.
Cheers
Depends what size but was put in there tbh my one is a 20mm but I had a 19 in there before... Have seen 21mm too.
On the 306 waiting list.
Threads: 14
So it's just a socket and not a square shaped plug or anything.
Threads: 36
18
Car Model/Spec: DT
(05-01-2013, 11:13 AM)DanWY Wrote: So it's just a socket and not a square shaped plug or anything.
Could have a 1/4 inch drive in the centre but normally have a socket option too. I haven't seen a square plug before.
Threads: 198
135
Nope, should just be a regular 20mm ish hex plug. There's a recess in it for a square tool too if you somehow manage to round it off.
Threads: 14
Cheers for that Jake! I am sure I will find out when I get it done later on.
Threads: 14
Thanks for all the info. I am struggling a bit as not jacked this car up before and a bit unsure of if the points where I have got the axle stands at the moment is ok.
If not could someone advice as to where would be better to put them.
Threads: 36
18
Car Model/Spec: DT
That's fine, it's where I put my stands too
Threads: 14
I have moved them to the point in the guide. I couldn't see it before I looked at the picture haha. Car is running the cleaner through now then time to drain the old out and in with the new!
Threads: 141
35
the subframes the best place for axle stands like you've done, makes me cringe when you see people supporting the weight of the car on the sills alone
Threads: 14
Yeah I have just moved them further back into the bolts where it attaches. I would never support it on the sills as they are prone to rusting, you have got to be stupid to put them on there I would think.
Threads: 14
All done now! Went easier then I expected. Was all done in about 30 mins or so.
Threads: 226
24
Yeah all simple stuff bud! Glad it went well, hopefully you'll get a few extra mpg as well!
Threads: 14
Hopefully. Trying to decide if I need new glow plugs now and also need to get the aux belt sorted.
