ac button to switch on fans
Hi guys need a little help
I've removed my air con rad ready to fit a fmic so no more a/c but can i still use the a/c button in the dash to kicking the fans when i need to
cheers
Yes it can be done I'm sure there is a guide. As simple as abit of wire joining 2 pins together on the brown 4 pin plug on the left hand side of the engine bay near the washer bottle filler neck iirc pins 1 and 3 but double check as I maybe wrong Smile
You have pm mate Smile
I have been told its pin 1 and 3 for high speed Smile
Team Doesn't own a 306
(15-12-2012, 03:46 PM)Danny2009 Wrote: I have been told its pin 1 and 3 for high speed Smile
It is mate checked it out. i did do it on my 6 just to check and it does work well Smile
I'm going to be doing it to mine oem fan switch ftw
It does work very well i still need to sort mine out as it was only temp to make sure i had the correct pins Smile
1 and 2 for low speed, 1 and 3 for high speed
Is there a nack to getting it working ive just put a wire in pin 1 and 3 also 1 and 2, ignition on air con button on but no fans Sad
yea with the spring clip facing up 1 is closest to the engine if that makes sense
Yea it's numbered on mine that's the way i did it :/
I remember trying this and no fans came on so turned engine off with the key but it still kept running for an extra min like a turbo timer haha panicked and plugged it bk in lol
Need to have another go
Iirc you should also unplug the ac pump from what I have read
Thanks guys very helpful
  Fans...HDi fans... HDi slimline fans... wiring.. toseland 3 3,456 07-09-2015, 09:52 AM
Last Post: cully
  Wiring Up Fans to a Timed Switch? bigcheez2k3 8 6,188 22-06-2013, 10:53 AM
Last Post: cully
