		When I first bought my gti, first thing I did was a cambelt. Didn't replace the waterpump as buying the car had properly cleared me out but it did need doing. So anyway, 7 months down the line and I've had a new pump, coolant and stat sitting in my room for 5 months
What I want to know is where the bloody hell do you get the tool for adjusting the tensioner? I've done 4 gti cambelts since using a home made tool but its a bit fooked now. The 1.8 was so much easier as it was just a spring loaded tensioner yo could move with a screw driver. It's basically a square hole in the tensioner, too small for a 3/8 ratchet but too big for a 1/4.
	Threads: 130
 82
 Car Model/Spec: 106 GO-NAD
		Same size as the gear box drain plug? 8mm square?
		Errr it could be actually!
	Threads: 130
 82
		If it is, I've got one of those keys
		Lad. If so, fancy helping me do a cambelt tomorrow if the weather is any good?
	Threads: 130
 82
		Might do. Might be doing my sisters brakes, dependant if I've fixed the nad or not really, or if I can be f*cked to go to redhill
	Threads: 18
 Car Model/Spec: Ph1 Sigma DT
		 (07-12-2012, 01:10 PM)Parksy87 Wrote:  Grind an 8mm allen key?
That's exactly what I did but it didn't last long
	Threads: 226
 24
 Car Model/Spec: A3 TDi
		You can buy sets of those proper drain plug sockets.. Would probably be a useful investment
	Threads: 90
		also same size as a door handle pin, which takes 2 seconds to weld to an old socket...
You can tell who the farmer is in this thread
	Threads: 130
 82
		I tried that on the gearbox drain, kept twisting it. it was mad of cheese. soft cheese. Brie probably.
	Threads: 448
 51
		Squeezey cheese?
		 (07-12-2012, 05:11 PM)darrenjlobb Wrote:  also same size as a door handle pin, which takes 2 seconds to weld to an old socket...
ah you know i never thought of that!
	Threads: 90
		 (07-12-2012, 05:24 PM)samass Wrote:  I tried that on the gearbox drain, kept twisting it. it was mad of cheese. soft cheese. Brie probably.
Dont buy your door handles from b&q?
	Threads: 130
 82
		Who said I bought it?
I actually found it in the garage...
	Threads: 448
 51
		 (07-12-2012, 05:46 PM)darrenjlobb Wrote:   (07-12-2012, 05:24 PM)samass Wrote:  I tried that on the gearbox drain, kept twisting it. it was mad of cheese. soft cheese. Brie probably.
Hahaha amazing!!
	Threads: 29
		Figured out how an auto tensioner works?
		 (07-12-2012, 08:07 PM)KrisB Wrote:  Figured out how an auto tensioner works?
Yeah its easy why?
	Threads: 61
	Given 6 thank(s) in 5 post(s)
Exactly what i used but got an adjustable spanner on it.
	Threads: 22
 Car Model/Spec: 1998 2.0 16v XSI
		I ground an M12 bolt square and welded a bar on, but i'm a tight arse..........
	Threads: 16
 Car Model/Spec: Supercharged Gti-6
		I've got proper tools now I work for a pug /Citroen garage however before I've  found when using an 8mm drain plug socket it gets in the way of the 13mm bolt on the tensioner. I've been known to use a mini pry bar behind it to lever the tensioner over before.
Also worth noting I've seen many a 6 engine destroyed (including my own car when I bought it) by water pump bearing failure or the veins on the back falling off and wedging up.... So get it changed   .
