Threads: 17
Car Model/Spec: 93' 405 GLDT
Quick few questions for fellow oil burners
Finally got my stage one tune done after some much needed advice from you guys.
I've seen on a few websites that ppl have de filtered their cars, is this safe to do?
and what's the benefit to unplugging the egr valve
Thanks in advance
Threads: 87
31
Unplugging the EGR valve isnt really worth doing unless you are going to take off the inlet manifold and clean it out properly too.
De-filtering a car isnt great to be honest. It most likely wont do any damage over the short term (~5k) but over long periods it will wear the engine out more and fill the compressor housing with shit. The only reasons most people do it are for 1. Noise, and 2 because fitting an intake system/filter onto a bigger turbo is a bit of a ballache and most people cant be arsed. Personally keep it filtered, but replace the standard air intake piping and box with a bit of flexi pipe off the turbo and a cone filter.
Threads: 28
2
Car Model/Spec: Phase 4 Silver HDi Estate
05-12-2012, 08:19 PM
(This post was last modified: 05-12-2012, 08:21 PM by Kwik.)
egr unplug is a good thing. make sure engine is stone cold when you do it or it will be open a bit giving you leak. is green plug behind battery housing just unplug and there you go. but be prepared for loads of smoke until inlet cleans itself lol
De-filtered only good if you want to increase the likely hood of something getting sucked in and destroying your turbo. yes alot of people do it but i wouldn't and that is my opinion. Filter's are used for a very good reason and don't disturb air flow if they clean
Threads: 17
Cheers for the advice mate,
Any suggestions on the cone filter to use?
Threads: 28
2
Me personally have stuck with the stock set up there is a mighty car mods youtube that shows why but others may disagree
Threads: 87
31
Biggest problem with the standard system is the restrictions in the intake piping.
Threads: 17
I've seen the mighty mods video mate, to my understanding they basically sais that there were no power gains, in some cases a loss, all it can go is increase flow?
Threads: 28
2
05-12-2012, 08:32 PM
(This post was last modified: 05-12-2012, 08:33 PM by Kwik.)
none what so ever and brings me to my next one
Me personally never noticed much of a difference from Pat i changed to a cone and did a extra cold air intake so with Project T i've stayed stock and Project T goes way better
But everyone experience is different so what i felt never worked may work well for others
Threads: 28
2
The thing is i'm off the thinking peugeot put a lot of R&D into the intake system so it's designed that way for a reason.
Yes it has restrictions but if a cone would be better on the end of it wouldn't they have done that in the first place?
