Threads: 37
My baby is broken
For the last couple of days my steering has been really heavy. Also hard to change gears at times. Arrived in Blackpool about an hour ago and all of a sudden a horrible grinding noise started. I can put it into any gear but if I try to move it grinds.
Threads: 31
4
Car Model/Spec: tu5 bitza/cherry dt
Given 5 thank(s) in 5 post(s)
17-11-2012, 09:31 PM
(This post was last modified: 17-11-2012, 09:38 PM by 306Dan.)
At first glance sounds like the gearbox has $h*t itself,without been there of a vid i cant really say sorry mate, steering sounds like a seperate issue tho poss a leak causing low pressure
Threads: 37
How much am I looking at?
Threads: 142
58
Car Model/Spec: E46 BMW 320d
I agree with dan, sounds like gearbox is dead. My old 1.4 did that to me twice. The gearboxes on these TU engines are made of cheese anyway. Scrap it and get an XUD.
Threads: 37
I'm absolutely devastated. Had it nearly 2 year an first thing to go wrong. Hope it isn't gonna cost loads. Can it have anything to do with the cv?
Threads: 31
4
17-11-2012, 10:21 PM
(This post was last modified: 17-11-2012, 10:24 PM by 306Dan.)
you can pick up a decent box for round 40 quid, and most scrappies will honour a months guarantee.
and for the price of a clutch 25 quid you might aswell lobb one in for good measure, just make sure you fully drain the old box and refresh the oil.
Its normally the diff in the tu boxes that are made from swiss cheese but if you change the oil yearly i.e. when you service the engine you normally dont have a problem.
however if the rh half shaft bearing has given in, it will cause premature wear of the diff bearings and cause the same fault
Threads: 37
So when I get it home tomorrow what should I look for mate?
Threads: 31
4
18-11-2012, 09:43 AM
(This post was last modified: 18-11-2012, 09:53 AM by 306Dan.)
Depends on your engine, post engine and location and ill see if I can help out
But then again if I'm right which someone will correct me if not all tu gearboxes are the same for the 306, easy way to find one is fleabay a 306 1.4 or 1.6 gearbox
Threads: 37
Ye it's a 1.4. I'm in stoke on Trent pal
Threads: 31
4
Ill see if I can find one local to you then
Threads: 37
Would gti6 driveshafts be ok on my 1.4?
Threads: 31
4
18-11-2012, 05:13 PM
(This post was last modified: 18-11-2012, 05:20 PM by 306Dan.)
nope gti6 drive shafts are a different size, only 1.4 and 1.6 are the same
there doesnt apear to be any gearbox's on the net within 50miles of you, i would check your local scrapppies for one on monday
Threads: 37
I'll go round when I get chance. Hard to get to them now  gutted there's a pair of Gti ones for 99p up the road
Threads: 37
18-11-2012, 06:25 PM
(This post was last modified: 18-11-2012, 06:25 PM by bowers.)
Are ye gearboxes coded?
The**
Threads: 31
4
Its the MA type box, theyre fitted to tu's in 106 206 306 and saxo's so should be easy to find.
just need to make sure its got the right clutch setup i.e. cable clutch or hydraulic
Threads: 37
So I can use a gearbox from any of those cars?
Threads: 31
4
19-11-2012, 11:04 PM
(This post was last modified: 19-11-2012, 11:16 PM by 306Dan.)
yup pretty much they fitted the same naff box and same diameter half stafts to anything with a tu engine in
if you look at a saxo box make sure its not the vts as it has a shorter final ratio i.e. revs more for the same speed
Threads: 37
got a gearbox and getting it fitted for 200 all in. hope thats the end of it =[
Threads: 31
4
is that with a new clutch, if so thats not a bad price at all
Threads: 37
no not having clutch done lol not got anymore cash
Threads: 31
4
kk it least it'll be back on the road for you
Threads: 37
Yep  just hope the clutch doesn't go!
Threads: 31
4
dont say that it'll be fine, at least with a tu there isnt a huge amount of power
Threads: 37
i know just wish i had the cash get it done at the same time! just need be reeaalllllly sensible when driving. OAP stylee!! haha
Threads: 37
My baby is back on the road  feels ALOT slower now though :/
Threads: 31
4
What speeds is it doing at 3k rpm every gear
Threads: 37
dont know ill check when i finish work
Threads: 55
17
Car Model/Spec: 406 V6
Probably got a higher FD.
Threads: 37
Fd?
So at 3000 it's 15,30,40,50,65
Threads: 31
4
Final drive, I.e the diff in the gearbox.
The revs to speed is right to my 1.4 with 15" wheels on 50 profiles, give it a couple of days see how it goes if not we'll do some more head scratching
And does it feel slow as in acceleration or top end?
