Threads: 7
Its on a 306 hdi and I used an elm 327 with pcmscan
I unplugged the egr and cleared the code for that which was also on there
thanks
cheers
Threads: 465
114
Car Model/Spec: Vauxhall
p00c8 = P00200 = Injector Circuit Malfunction
p00cc = P00204 = Injector Circuit Malfunction - Cylinder 4 S2000PM1/2 - Injector control # 4. Open circuit or short to earth.
P02XX = Fuel and Air Metering
if you get letters in the obd codes it normaly needs converting to Decimal as its in Hexadecimal
Threads: 117
119
That seems a pretty specific code, so i'm thinking wiring problems on injector 4 lol. It's not a problem i've seen before, but have a look about for burnt contacts, corrosion and broken wires, could even just be a bad earth.
