	Threads: 4
Car Model/Spec: Peugeot 306 1.9 XUD 1995/N
		03-11-2012, 05:11 PM
		Hello all! Awesome forum, hope to get along and around
Where can I find the temperature sensor which triggers glowplug pre-heat?
For me it acts random even at same ambient/engine temperatures! I.e., quite often pre-heat indicator does not light up in winter  and does lit up in summer at times.
Cheers!
sledge
	Threads: 28
Car Model/Spec: Phase 4 Silver HDi Estate
		the glow plug relay is behind battery i think that controls most things
	Threads: 4
		Cheers Kwik,
Just checked with multimeter: glow plugs are always heated for 15-20 seconds, the pre-heat lamp does not turn on on instrument panel.
If it ever turns on, stays for just a couple of seconds - irregular. I tested the lamp wire from the glow-plug relay box, and it is dead from there.
But the glowplugs apparently are heated regardless.
So the solution is on a cold day keep ignition on for 20seconds and repeat several times.
Wonder if replacing relay box would solve instrument panel LED behaviour..
Cheers,
sledge
	Threads: 28
		get another one from breakers and switch it over see if that does the trick
	Threads: 119
Car Model/Spec: MG ZS180
		The light only ever stays on for a few seconds, but if you wait you will hear a click after another 13 seconds or so when they actually turn off, also the dash lights will get brighter when they go off.
