206 wheels
Quick one, After a set of steels for a 206cc. By any chance, are they the same offset as 306 ones?
no they are a different et if i remember i think its 10 or 15mm spacers to get 206 wheels on a 306 at the correct et
As above it's not, but should be fine as it all it means is they'll stick out an extra 13mm (ish). As standard they probably sit into the arch a fair bit as 306's
As curt says not the same but do fit, it prob will actually sit in the arch better than an OE 206 one, I.E it shouldnt look so set in
Fair enough. No worries. Sure i can pick up a set of 206 steels cheap. Its just i know where i can get a set of 306 steels even cheaper lol
Get your spare from the 1.8 and test fit
(01-11-2012, 08:38 PM)puglove Wrote: Get your spare from the 1.8 and test fit
Would if i still had it!
Try grants spare then lol
