		Quick one, After a set of steels for a 206cc. By any chance, are they the same offset as 306 ones?
	Threads: 115
26
Car Model/Spec: 306
		no they are a different et if i remember i think its 10 or 15mm spacers to get 206 wheels on a 306 at the correct et
	Threads: 78
49
		As above it's not, but should be fine as it all it means is they'll stick out an extra 13mm (ish). As standard they probably sit into the arch a fair bit as 306's
	Threads: 208
60
	Given 5 thank(s) in 5 post(s)
		As curt says not the same but do fit, it prob will actually sit in the arch better than an OE 206 one, I.E it shouldnt look so set in
![[Image: DSC_0190-Copy_zpsf093f84d.jpg]](http://i1038.photobucket.com/albums/a468/167gti8/DSC_0190-Copy_zpsf093f84d.jpg) Member of 99% warning or your nothing club!
		Fair enough. No worries. Sure i can pick up a set of 206 steels cheap. Its just i know where i can get a set of 306 steels even cheaper lol
	Threads: 208
60
		Get your spare from the 1.8 and test fit
		 (01-11-2012, 08:38 PM)puglove Wrote:  Get your spare from the 1.8 and test fit
Would if i still had it!
	Threads: 208
60
		Try grants spare then lol
