	Threads: 36
Car Model/Spec: GTI6 with XUD
		hi ive got a dturbo with a Bosch and i was wondering what the best mix to start of with for example 50/50 of diesel and veg, also are there any problems that will follow from using veg oil
cheeers
	Threads: 171
46
	Given 1 thank(s) in 1 post(s)
		Only problem is when it gets cold but just thin it down with petrol or similar
No set percentage just dive in at whatever you want
Keep a spare fuel filter in the boot in case and I'd change it 2x as often at least
	Threads: 202
58
		any amount is saving money, even a gallon a tank.
doesn't really seem to matter though, until it gets cold!
	Threads: 186
38
Car Model/Spec: MG ZR VVC
	Given 21 thank(s) in 19 post(s)
		2 stroke is meant to help thin it out a bit when things get lumpy
	Threads: 82
14
Car Model/Spec: P0XY Ph2 Dtub 5dr
		If you can find some sunflower oil at a good price put that in instead over the winter as it needs to get a lot colder than veg before it starts going lumpy.
	Threads: 91
12
Car Model/Spec: 306 D Turbo
		As already said change the fuel filter after 100 mioes as the veg is quite corosive and will clear all the shit out of the tank/lines and clog the filter very quickly. Then change it at half the usual recommended intervals.
As for the mix, I just run it straight in the summer and a 50/50 mix in the winter.
