Help, disconnected vaccum pipe
Got the air con out today and i have a vaccum hose thats been disconnected in the proccess. It runs from the top left of the engine bay and along the bulk head then goes down, where should it then connect to?!
Thanks for any help.
Ian
possibly the EGR valve by the sounds of it mate
if its got blue tape marker on the end it part of the egr system, it goes to the air doser on the air inlet just before the manafold bend its a right bitch to get to
No tape marker, its only got suction at low revs
trace it back along the bulk head. does it go to a solinoid valve ?
or has it broken off from the vacuum pump conection block to the left of the battery against the bulkhead?
Goes to a solinoid valve, theres two one above the other, its from the the 'out' of the top one
yup as i said before then it goes to the air doser on the air inlet just before the manafold bend
Awesome cheers.
