Threads: 82
27
If anything it'll give you gains! probably small but similar effects to a proper de-cat tbh!
Threads: 130
82
Car Model/Spec: 106 GO-NAD
id get a pipe welded in. the expanding of the pipe into an open box actually slows down gas flow, true, itd be minimal, but a straight pipe would be better for flow than for a pipe going into an empty box, then back to a pipe.
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
i was about to say this ^^^^^^^^^^^^^^^^
you basically create an expansion chamber; which slows down flow; straight pipe of the same diameter throughout is the best for optimal flow.
Phaes 1 GTI 6 - Onyx Black
Threads: 198
135
Correct, but pulse tuning is best for back pressure in an NA car, so the expansion chamber may actually be less detrimental to torkz than a straight pipe..
Threads: 130
82
pulse tuning comes into the game when you're looking at the mani and the each of the pipes (equal length, unirform radius, etc) going into the collectors.
the empty box would probably give you more low-mid range torque as the back pressure would be increased, where as the straight pipe would increase top end
Threads: 82
27
Tbh if the rest of the system was straight through it'd probably be good to give it some extra back pressure to increase midrange torque slightly
