bosch seized
bosch seized
hi, this is my first post so bare with me please, i recently bought a bosch pump off ebay, 11mm head gov mod... but when fitted i went to turn the engine over via crank pully as to test timing. but i hit a snag as it would lock up and jump a tooth after a lot of head scratching i found the new pump was locking up?? i have spoken to the chap i bought it off and its going back this week end, ive worked on these pumps before but only as far as gov mods and pin grinding so am lost as to whats going on? figured id throw it out there see what you guys thought.
Most likely had no diesel in it so just rusted up as its all smooth surfaces in there that don't like fresh air
Or bad pump rebuild
www.prestige-auto-care.co.uk
(19-06-2012, 09:40 PM)Jenkosowls Wrote: Most likely had no diesel in it so just rusted up as its all smooth surfaces in there that don't like fresh air
Or bad pump rebuild
yea looks good nick, am guessing bad rebuild then... ahh well
Hes probably f*cked up on the rebuild
(19-06-2012, 11:57 PM)Dave Wrote: Hes probably f*cked up on the rebuild
This^ Get the lid off and have a look
HDi Cabby Project Click
Sounds like someone cocked it up, somethings binding somewhere / plunger hitting end stop due to bad shim use....
[Image: sigi-2.png]
had top off cant see anything obvious may have to dig deeper
Try rotating the pump by hand now the lid is off and look for anything caught but you may need to take the head off yet!
tbh mate, I wouldnt touch it, and just send it back! if he see's you've had it apart, he may reject it.
Who was it bought from out of interest?
JP
Removed the pulley locking bolt? ninja
sent it back guys, got it from a chap in newcastle he had built a few and had himself a quite mad 205, i got a new one off him and now this one wont start so begun building my own, out of interest would a 9mm pump have the capability to fuel a tdo4? im after around 160 bhp also any one else relocated a turbo? im just building a setup with td04 mounted in place of oem airbox?
9mm pump will fuel a td04 no problem. also, relocating a turbo to the oem airbox location would be a bit of a fail, the turbo ideally wants to be as close to the head/exhaust ports as possible....
Im a fail Smile ^^
How come second pump wouldnt start? No fuel output at all? sure you had max fuel in far enough / solenoid working?
[Image: sigi-2.png]
Yours isnt in the oem airbox location though?! lol yours are battery/gearbox mounted....
