22-12-2012, 11:04 PM
anyone got some good pictures of gearbox mounted turbos??
curious about positioning and plumbing....
thanks, Piggy
thanks, Piggy
curious about positioning and plumbing.... thanks, Piggy Wishes for more power...
22-12-2012, 11:48 PM
nah thats great....curious though that theres no exhaust outlet pipework...was that tough to get round under the tunnel??
22-12-2012, 11:52 PM
It's 3" and tight, I might have to change it with the new gearbox I have and the cable linkages.
23-12-2012, 04:09 AM
Serious its not rocket science especially for a pug tech like yourself mtfu and just do it!!!!
23-12-2012, 12:25 PM
aye but always happy to take advice or see someone who has done it/knows better!
23-12-2012, 05:43 PM
(This post was last modified: 23-12-2012, 05:44 PM by ozonehostile.)
this is my setup
I had to rotate the turbo 90* so the outlet was on the right side, and as a consequence the exhaust out needed a right angle bend to get it all to fit. used the biggest possible pipe that would fit to try compensating for the sharp bend in the pipe, seems to working fine
thanks chap...answers my Q about what to do if you rotate it...you make a bracket for the boost control
thanks for the info PS very clean engine bay by the way...is that a catch tank...centre front..? Wishes for more power...
23-12-2012, 09:36 PM
(23-12-2012, 09:28 PM)Piggy1987 Wrote: thanks chap...answers my Q about what to do if you rotate it...you make a bracket for the boost control yeah its a catch tank, had issues with oil going everywhere been spat out through the breather, catch tank solved it
'09 Mercedes E320cdi wagon '99 306 gti6 (23-12-2012, 09:36 PM)ozonehostile Wrote:(23-12-2012, 09:28 PM)Piggy1987 Wrote: thanks chap...answers my Q about what to do if you rotate it...you make a bracket for the boost control I was gonna get a catch tank, but meh. I have my oil breather pipe off my intake just facing down towards the floor, like a boss.
24-12-2012, 12:54 AM
Would using the old manifold work If you made up a plate and pipe to bolt onto it instead of the turbo? Then route it up on top of the box?
24-12-2012, 01:00 AM
(24-12-2012, 12:54 AM)Ollie Wrote: Would using the old manifold work If you made up a plate and pipe to bolt onto it instead of the turbo? Then route it up on top of the box? dont quite understand what you mean mate
24-12-2012, 08:53 AM
me neither....
that oil catch tank.. did you make it yourself out of a filter housing?! looks real smart but not mad shiny like all others Wishes for more power...
24-12-2012, 09:15 AM
(24-12-2012, 12:54 AM)Ollie Wrote: Would using the old manifold work If you made up a plate and pipe to bolt onto it instead of the turbo? Then route it up on top of the box? He means making a flange to bolt to original manifold with a Pipe going from that to the new turbo position, im sure i have seen this done, unless you have to funds to get a full manifold made like darren has done many times lol It would be a lot cheaper this way but unsure how efficient it would be, im sure someone will be along to correct me or explain more
24-12-2012, 10:39 AM
(This post was last modified: 24-12-2012, 10:43 AM by ozonehostile.)
(24-12-2012, 09:15 AM)CJ_Derv Wrote:(24-12-2012, 12:54 AM)Ollie Wrote: Would using the old manifold work If you made up a plate and pipe to bolt onto it instead of the turbo? Then route it up on top of the box? ah i get it, in theory it could work yeah but like you said, the design wouldnt be very efficient and would require alot of precision work with either a welder or gaskets to make sure theres no leaks. it would probly be easier just to modify the original mani into a 4-2-1 than try and make a decemt plate and pipe. pleas excuse the brilliance of my ms paint skills, but this is what ive done (24-12-2012, 08:53 AM)Piggy1987 Wrote: me neither.... Its a bosch catch tank, another borrowed truck part haha
24-12-2012, 10:52 AM
Wouldnt necessarily difficult as long as its a flat face (ie like adaptor plates) not hard at all just couple of bends and a welder then, simples, Im very sure this was done by a mate i know chris on his hdi running a gearbox mounted turbo,
i think the only downside would be unequal length but looking at it they all join at same point so in theory they are the same length jsut brought together earlier
24-12-2012, 12:32 PM
(24-12-2012, 09:15 AM)CJ_Derv Wrote:(24-12-2012, 12:54 AM)Ollie Wrote: Would using the old manifold work If you made up a plate and pipe to bolt onto it instead of the turbo? Then route it up on top of the box? Yep this what i mean, thanks lol. Posted that half cut on my phone last night. Im not sure how efficient it would be but im sure it would be a lot less hassle than building a full manifold.
24-12-2012, 12:58 PM
(24-12-2012, 10:52 AM)CJ_Derv Wrote: Wouldnt necessarily difficult as long as its a flat face (ie like adaptor plates) not hard at all just couple of bends and a welder then, simples, Im very sure this was done by a mate i know chris on his hdi running a gearbox mounted turbo, Certainly worth a try though, and IMO if the lengths aren't a consideration when fitting a turbo down the back of the block, then just "extending" the mani with a single pipe isn't going to make much difference I'd have thought. Welding and fabrication projects undertaken, contact me for more information.
24-12-2012, 01:38 PM
As with anything turbo related, more pipes = more lag yes. But as long as it's not a twin scroll, bodging a pipe on the end of a standard mani would be my choice to relocate it. There's so many rudimentary turbo conversions that are a bit of a bodge, this would make f*ck all difference in the grand scheme of things.
24-12-2012, 07:48 PM
(24-12-2012, 01:38 PM)cwspellowe Wrote: As with anything turbo related, more pipes = more lag yes. But as long as it's not a twin scroll, bodging a pipe on the end of a standard mani would be my choice to relocate it. There's so many rudimentary turbo conversions that are a bit of a bodge, this would make f*ck all difference in the grand scheme of things. Exactly what I would do, would make it so much easier and you'd notice no difference.
24-12-2012, 11:12 PM
this ^^^^
I will be getting 3 flanges made...one for original mani...one for turbo in and one out... then tack up pipework with all in place then get decent local welder to finish. simples...I assumed this what most do anyhow...esp as 4-1 with it going to box would mean diff length pipes Wishes for more power...
25-12-2012, 09:40 AM
To be fair, You would be suprised how much extra lag the relocation will make, I certainly notice a huge difference in lag, that said, with a well made manifold, the flow is equally as noticably better / engine so much more rev happy, and also with equal length primarys, the noise changes to a lovely tone
25-12-2012, 10:41 AM
bet would cost stupid money to get custom mani made with equal primarys tho!!!
25-12-2012, 11:24 AM
Or just make it yourself, only costs you welding supplies then. And what darren said, the sound an xud can make with a decent mani and a straight through exhaust is very pleasing to the ear, almost sounds like a scooby impreza just without the offbeat lope of the boxer engine
'09 Mercedes E320cdi wagon '99 306 gti6 (25-12-2012, 11:24 AM)ozonehostile Wrote: Or just make it yourself, only costs you welding supplies then. And what darren said, the sound an xud can make with a decent mani and a straight through exhaust is very pleasing to the ear, almost sounds like a scooby impreza just without the offbeat lope of the boxer engine I see a pattern here. Xud's, td04's, "sounds like a scooby impreza"....we're slowing turning them int..... o_O I'm curious as to why people are relocating them? Is it just so it's easier to change turbos? To hard to fit turbos down there? Or am I missing something? Happy Christmas x
25-12-2012, 11:53 AM
Plenty of room down back, I have a dimensionally huge turbo and fits no issues.
25-12-2012, 11:57 AM
By relocating the turbo you can fit massive ones that would no way fit behind the block, plus access is no problem when its over the gearbox. In my opinion it looks a hell of alot better too having the turbo on display next to the engine. You can drasticly improve the flow rate efficiency with a relocated turbo as it allows for bigger downpipes and if properly built, better flowing exhaust manifolds.
intercooler pipe rooting also better as you dont need to get to get any pipes behind the engine
25-12-2012, 12:04 PM
There's a lot of room between the driveshafts and bulkhead! The engine sits at 60 degrees so the lower it sits the more space ypu have.
Gear box mounted turbo | Cbray2003 | 20 | 3,598 |
11-01-2013, 04:07 PM Last Post: Matty |
