Threads: 115
26
Car Model/Spec: 306
As my air con is nackerd in the 6 i am going to remove it inc the pump from The engine.
Does anyone know what parts i need to do this? How much they cost? And where to get them from?
Thanks in advance
Threads: 448
51
Iirc don't you just need a new belt? From a car with the non air con? Like the rallye
Threads: 138
72
Car Model/Spec: Mincebus
You need the non-ac aux set-up from the rallye. Slightly different pulley arrangement iirc...
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 115
26
Car Model/Spec: 306
22-06-2012, 11:57 AM
(This post was last modified: 22-06-2012, 12:07 PM by spike2002.)
Thats what i was thinking but ive read that mayb there is more to it than just changing the belt to a smaller rallye one? Tensioners or a pulley mayb?
Ed do you know if i can get this as a kit? If so any ideas on price and where from?
Also would the aux set up be the same from a non a/c 2.0 16 xsi?
Threads: 448
51
Just buy the rallye parts instead of the '6 equivalent
Threads: 189
10
Car Model/Spec: E39 ACS 535i
Yep, just get the rallye tensioner and idler.
Also remove all the pipework while the engine is out of the car.
Threads: 138
72
^^ Chris he's not taking his engine out?! His AC Is knackered that's all!!
I think Lynxengineering sell a kit, but the simplest way would be to have a quick search of the '6 forum, find out what the rallye set-up involves, and just buy that with a rallye belt
I'll have a peek when I get a minute, see if I can find any info on it
Threads: 448
51
I could walk outside and look at my rallye?
And ed seriously stop with the lynx!!! He wants to buy them not get bummed for them
Threads: 138
72
(22-06-2012, 12:50 PM)Matt Wrote: I could walk outside and look at my rallye?
I wouldn't bother mate, you wont get an accurate representation; as it's a ph2 most of it's probably fallen off already...
AND SO IT BEGINS
Threads: 115
26
Car Model/Spec: 306
The engine is currently out of the car so will be removing all the a/c pipes and that aswell
Matt any chance you can pm me ur reg and chasi number mate and i can use that to give my local motor factors so i get the rite parts
Threads: 169
91
Can anyone throw a link/part# up for the rallye aux setup. Having trouble finding it
Thanks
Threads: 130
82
Car Model/Spec: 106 GO-NAD
22-06-2012, 04:27 PM
(This post was last modified: 22-06-2012, 04:35 PM by samass.)
found this on the '6 forum
looked on the gsf site, they only have the part nmbers for the ac set up, and my service box is broked
Threads: 448
51
Threads: 115
26
Car Model/Spec: 306
Thanks sam  big help mate will compare that pic to my a/c setup and see exacly what i need if you can get the part numbers mate when its working again that would be awsome
Threads: 581
195
Threads: 448
51
Who needs auto windows? Never had em in the xsi either!
Threads: 15
1
Car Model/Spec: P2 Nile GTi6
I also want to know this information
Threads: 11
1
Car Model/Spec: Rallye
Thread below should help you lot out a bit:
http://www.306gti6.com/forum/showthread.php?id=148822
Retro is cool anyway & windy windows are retro
Threads: 115
26
Car Model/Spec: 306
Gatt38098 tensioner
Gatt36036 idler
Gatt6pk1163 belt
So these are the part numbers that are needed for gates thanks for the.link mate
Threads: 52
1
Car Model/Spec: Ph2 Dturbo
was just about to comment and say the hdi and dturbo to remove the ac pump you just use a 6pk1163
Threads: 15
1
22-06-2012, 07:17 PM
(This post was last modified: 22-06-2012, 07:20 PM by TheGateKeeper.)
this is the link on unipart... but which ones are they?
http://www.unipartautomotive.co.uk/Engin...Tensioners
Looking at the picture Bongo put up... its the £32.90 tensioner.. and the £38.70 idler... = £71.60 so then would need the belt?!
Threads: 115
26
Car Model/Spec: 306
Link only goes to unipart website mate
Threads: 15
1
22-06-2012, 09:01 PM
(This post was last modified: 22-06-2012, 09:02 PM by TheGateKeeper.)
Gay... Go to it and chuck Matt's reg in
UGCGBT6036 - Idler
UGCGBT8098 - Tensioner
Threads: 198
135
22-06-2012, 09:07 PM
(This post was last modified: 22-06-2012, 09:07 PM by cwspellowe.)
Go to a scrappy and find any xu petrol engined 306 and take the parts off that. £bumrape for the rallye parts, pennies from any other 306
Threads: 115
26
Car Model/Spec: 306
22-06-2012, 09:17 PM
(This post was last modified: 22-06-2012, 09:23 PM by spike2002.)
Are the parts the same tho?
Tgk got it now mate yh they look correct
Threads: 130
82
afaik, all the aux belt set ups on the xu engines are the same, with the only different being the ac or non ac. obviously. good shout on the scrappy, might have a butchers next time im down, all the ones there seem to have ac tho...
Threads: 581
195
Think some of the belts are different. PAS pulley on the 6 is smaller than the one on the 1.8 So some have a shorter belt.
Threads: 448
51
T553 rwy that's my reg for anyone looking for parts
Threads: 115
26
Car Model/Spec: 306
just so people can see the difference this is my standard 6 setup with aircon
Threads: 11
1
I tried to get some screenshots from ServiceBox but I can't find the right section for it. If anyone needs it and knows what section it is post it up and I'll grab some screenshots.
