	Threads: 1
		Hello am new to hear. I have changed the grenade thing and even bypast the filter and still get air in the line where could this be getting in it it's getting annoying when it Dosnt start needs a tow to start most of the time :think:
	Threads: 42
Car Model/Spec: 306 XRDT
		Leak Off pipes letting air in?
	Threads: 208
60
	Given 5 thank(s) in 5 post(s)
		Bleed niple tight?
Is it leaking fuel anywhere that i could drag air through?
	Threads: 1
		Yeah av just found out that the injector end cap is damaged so a will get a new 1 tomorrow a will let you know tomorrow wether this is the fix thanks
	Threads: 1
		Thanks any idea how much 1 is am thinking a quid or something lol
	Threads: 1
		Ok so av put a proper end cap on and still no luck starting it still has to be towed to start help please
Car Model/Spec: 306 D Turbo
		Is the engine completely dry with no fuel leaks? If so, check the in-tank filter and fuel lines for corrosion.
Do you have a clear pipe to see the bubbles or is it just rough to start?
	Threads: 1
		Yeah a have a clear pipe so a see the bubbles and when it is running ther is a lot of them when you rev and let off ther is a burst of bubbles go to the pump
