07-06-2012, 08:55 PM
		For the people who have ground their LDA pin, what did you use to do it? Dremel type tool?
					May be an obvious question, buuut..
		07-06-2012, 09:03 PM
	 cwspellowe Wrote:Me too, but my Dan! tool is broken for 6 weeks It's okay, the Dan! tool is made by Snap-On so has a lifetime warranty. Captain Standard
		07-06-2012, 09:05 PM
		I used a bench grinder    and finished off with a dremel and sand paper.
Stage 2 XUD Sedan
		07-06-2012, 09:06 PM
	 strictly_derv Wrote:I used a bench grinder Really?! Surely the bench grinder was way too big? I really need to grind mine once the boost leak has been sorted..
		07-06-2012, 09:12 PM
		Am I right in saying your pin is from a rover?  You're right about it being hefty though, that looks really weak in the middle!
		07-06-2012, 09:18 PM
		Yep got it from a Rover. All the cars at the local scrappy have missing LDA pins now haha. It does look weak but I doubt it will break and it's no biggie if it does TBH.
Stage 2 XUD Sedan
		07-06-2012, 09:37 PM
		May invest in a dremel and get mine done.
		07-06-2012, 09:46 PM
		Well worth doing, with this pin I've had to turn the fuel screw down nearly a full turn to clear the smoke at 26/7psi!
Stage 2 XUD Sedan
		07-06-2012, 09:51 PM
	 strictly_derv Wrote:Well worth doing, with this pin I've had to turn the fuel screw down nearly a full turn to clear the smoke at 26/7psi! Your doing it all wrong then, your not supposed to turn anything down.............ever, too much smoke mean that you need more boost................not less fuel, that is backwards progress
		07-06-2012, 09:54 PM
		Well because of my boost leak I was getting a load of smoke, so I am currently running with the pin at its steepest and its soo slow! But I was surprised at how much difference the pin alone can make, so can't wait to get it sorted.
		07-06-2012, 09:57 PM
	 mark_airey Wrote:strictly_derv Wrote:Well worth doing, with this pin I've had to turn the fuel screw down nearly a full turn to clear the smoke at 26/7psi! That is usually my philosophy but the wastegate spring must be weak and wont budge past 27psi.... the K04 will be my new boost producer soon though, no wastegate on that
Stage 2 XUD Sedan
		07-06-2012, 10:31 PM
	 mark_airey Wrote:strictly_derv Wrote:Well worth doing, with this pin I've had to turn the fuel screw down nearly a full turn to clear the smoke at 26/7psi! Was going to contribute to this..... but in actual fact mark is 100% correct  go find a bigger turbo ![[Image: 22f2b6b2-758b-4c1c-96fb-6fa9c6059b13_zpsf306b56b.jpg]](http://i585.photobucket.com/albums/ss299/Ha11elujaz0rs/22f2b6b2-758b-4c1c-96fb-6fa9c6059b13_zpsf306b56b.jpg)
		07-06-2012, 10:34 PM
		Yeah fk it, lorry turbo or gtfo
	 ![[Image: brokendown-1-1-1.jpg]](http://i1054.photobucket.com/albums/s491/n0v0s/brokendown-1-1-1.jpg) Dturbo GT2259s build thread; http://306oc.co.uk/forum/thread-3692.html Daily driver; 330d Msport (doesn't blow up!)
		07-06-2012, 10:47 PM
	 Dave Wrote:[Was going to contribute to this..... but in actual fact mark is 100% correct He knows this, he is already on it with the K04 + welded wastegate, just needs to actually fit it to the bloody car :roll:
		08-06-2012, 08:06 AM
	 mark_airey Wrote:Dave Wrote:[Was going to contribute to this..... but in actual fact mark is 100% correct You know it Mark :dance:
Stage 2 XUD Sedan
		08-06-2012, 08:56 AM
		Make sure its smooth though! else it'll wear down the pin over time and slowly you'll loose the variation of your on/off boost...
	 ![[Image: 22f2b6b2-758b-4c1c-96fb-6fa9c6059b13_zpsf306b56b.jpg]](http://i585.photobucket.com/albums/ss299/Ha11elujaz0rs/22f2b6b2-758b-4c1c-96fb-6fa9c6059b13_zpsf306b56b.jpg)  |
