Morette wiring
Why cant I find a simple guide....either written in some jibberish or the diagram is for the main beam/ side lights.....and I need to know how to wire the dipped beam in.
Anyone have a complete diagram or clear written guide?
Its for P2/3 morettes, coming from H7 to H4....unless H7's can be wired in?
Would it not be easier to look at and orignal ph2 headlight and copy the way it wire, or get scrap ones like i did and use the loom from them
I thought p2 and p3 lights were the same up to the point if the lenses?
I thought the wiring was exactly the same and you just needed the Phase 3 light stalk to make them work properly? Ive got some morettes which ive never got out the drawer since i got them. Ill have a go at some point!
Ph2 uses H4 bulbs and ph3 uses H7 so the loom is slightly different
I just made jump wires from the original connector to the morette ones
