	Threads: 171
46
		maybe one of the door seals is fooked or something?
gotta bear in mind well down here anyway we've not had some proper rain in quite a while, mine only leaks in the heaviest of rain
	Threads: 36
		I haven't had a chance to look at it yet as I finished it late at night and have been so busy since, but you could be right! I'm hoping it's something simple as that dash IS NOT coming out again, evaaar! I'd rather split open another set of valeos!
	Threads: 3
7
		You got a sunroof...? Either that or it could be leaking from your ariel!
	Threads: 36
		Yes, i have a sunroof but its not from there, well it can't be as its only after removing the dash (to change the heater matrix).
I might just jetwash the shit out of the front tomorrow and see. Its bound to be something silly.. perhaps from the windscreen area is what i'm thinking.
	Threads: 214
Car Model/Spec: 306 hdi meridian
		My 306 hdi was leaking in the boot, passanger door front and the aerial as well. Fixed the lot the car dry as hell boot seal, door seal and silocon on the aerial.
	Threads: 465
114
Car Model/Spec: Vauxhall
		do you want some gold fish?
	Threads: 19
Car Model/Spec: Xantia HDi shed
		Check you've put the cover over the blower intake back on properly, under the passenger side scuttle panel.
I didn't put it back on properly once after messing about with it and ended up with a puddle in the foot well!
