Threads: 198
135
Evening fellas, does someone fancy letting me know the common hose sizes in the engine bay? ie. fuel lines, boost compensator etc? Thinking of buying new and cutting to length rather than hunting for standard used ones.
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
For the life of me i can't remember the size, but know buying from ebay, altogether it cost me about £10. the return line's is the only different size you need.
compensator and filter hose are the same iirc
Phaes 1 GTI 6 - Onyx Black
Threads: 198
135
Think it's about 10mm, and fuel lines are about 8mm?
6-8mm... If you buy silicon pipes you can make it all fit, I've got 6mm everywhere and it fits, you might just have to use a bit of lube to get it over some stuff...
Threads: 198
135
If I went for 8mm all round it should clamp to the smaller stuff ok, right? Also the vacuum hose from pump to servo, 10mm?
Aye yeah.
I think vac pump to servo is 10mm aye.
Threads: 376
38
Fuel hose from filter to pump -
http://www.ebay.co.uk/itm/8mm-5-16-R6-F ... 1e60432d8b
and leak off piping -
http://www.ebay.co.uk/itm/DIESEL-LEAK-S ... 564688ab7c
found it.. Also posted in project thread. This was what I bought, was enough plus spares
