Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
The old part number is
0281002284
the new part number is
0281002493
Are these correct?
Threads: 110
20
Same as the one i got. should be fine, there seems to be the 2 slightly different types. One with like a filter on the end and one without. Swap the O ring over just be careful when removing it so you don't damage it as thats the main seal to stop the fuel pissing out.
Threads: 186
6
08-04-2018, 11:12 AM
(This post was last modified: 08-04-2018, 11:17 AM by JTaylor2005.)
The oring went on fine. I cant seem to push this one in far enough for it to meet the face. It gets stuck! I have checked the fitment of this part number on the bosch catalogue and it says it fits my fuel pump number 0445010010
Think I was just being a wimp. I think I was feeling the resistance of the new green o-ring going into place!
Threads: 110
20
Yeah needs a bit of force to push it in, pop a little bit of oil on the O ring to help it go in.
Threads: 14
Given 6 thank(s) in 6 post(s)
i had idle fluctuation i put a wall bro gss340 in and the idel is now stable
Threads: 49
You ever had it on diagnostics and watched the live data? Idle fluctuations could be caused by all sorts so bit of a guessing game... In my opinion beyond the filter should be spotless as it's 1 micron.
Threads: 49
Madmadmax- is the pump suitable for diesel as I see it listed for petrol? I want to fit an external pump but not sure what to go for yet.
Threads: 14
if its chemical proof for petrol whitch is a stronger solvent than diesel then it should be ok, i have it in my daily
