02-07-2017, 08:16 PM
Having a bit of a clearout. Prices are plus postage, or you may be able to collect from Leicestershire. I do not yet know if I am going to FCS. The list may be updated if I find more parts I have no use for. I also have a set of phase 1 morettes that need refurbishing but I need to inspect them and possibly put them in the WIW section.
Genuine gti6 catalyst, passed MOTs just fine but the outlet pipe snapped - £75
Beam hangar brackets - £10
Rear brake caliper stone shields/guards, these came off a rebuilt beam that had sat for a while, they were powercoated black but aren't looking their best anymore, however they are mostly fairly smooth and not pitted and corroded all over so good for refurbing. One is slightly bent but would probably go back straight - £15
Set of genuine, used rear axle mounts, car was only on 60somethingk miles when removed, but obviously they are 20 years old. Good for spares or for welding up to make solids - £10
Gti6 cam covers - £25
Rear wheel studs for stud conversion (no nuts, may also fit in front hubs), enough for 2 hubs/wheels - £10
Phase 1 aftermarket debadged mesh grille, needs sanding down and painting, as in the link below - £15
http://www.body-kit.co.uk/product.php/18...grille-abs
