Threads: 1
Car Model/Spec: 1999 306 1.4
Thank you so much. I need as much info as its my first cam/auxiliary belts change. Fingers crossed.
Sent from my SM-G900F using Tapatalk
Threads: 1
Problem two...
How do i release the tension on the auxiliary belts? It already doing my head in.
Threads: 87
48
There are a few different tensioners, I think with yours you loosen a bolt then use a 1/2 bar in the square hole to move it round.
Threads: 1
That will work on the cambelt but there is only one tensioner on the p/s , a/c belt with a torque screw in center but there is no tensioner on the gen belt?
Threads: 14
check to see of the alternator swing in and out
