	Threads: 448
51
		18-04-2016, 10:52 PM
(This post was last modified: 18-04-2016, 10:59 PM by Matt.)
		Looking at buying an oil cooler ready for summer track time as my temps go up from giving it death in the evenings so dread to think what it will be like in the summer
So afaik The eBay kits are bad. Are the coolers bad or is it the fitting kits?
I'd rather go for braided hoses and an fittings where possible
The only bit I don't really understand is the sandwich plate, I've looked and the Rallye has something that resembles it as standard, I'm guessing that's not it?
Also if possible id like to fit an oil pressure gauge at the same time, can this be done using the sandwich plate?
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg) TEAM CONROD SHITTING RALLYE!
	Threads: 374
38
Car Model/Spec: GTI 6
		I'm sure you can get the sandwhich plate for the oil cooler feed as well as a the gauge.
I think it's relatively straight forward. I also wasn't aware of dodgy eBay kits.
You looked on somewhere like demon tweeks?
	Threads: 101
Car Model/Spec: 306HDi 90 LX
		speaking of which, thermostatic, or non?
It goes, it stops (as reqd).
Hate Housework!
	Threads: 465
114
Car Model/Spec: Vauxhall
		mocal coolers have been getting bad rep recently
i bought
19row x 235 x 1/2Bsp APS cooler from jjcraceandrally via ebay
	Threads: 58
Car Model/Spec: Loads
	Given 9 thank(s) in 9 post(s)
		Use a Setrab cooler and a std take off plate, Hoses make to suit when you have everything positioned, Oil pressure just use the Phase 1 sender (M16) and move the low oil by the breather pipes to the right of the engine
	Threads: 61
11
		Thermostatic come on at 89 without its constantly on so if you going short journeys it will take awhile to get up to temp.
