Threads: 1
Car Model/Spec: 306 Meridian
04-02-2016, 09:51 AM
Hey all, fellow 306 driver here. My beloved 306 1.4 Meridian seems to have a problem. The last couple of days, when coasting - a very loud rattle is emanating, seemingly from right underneath the car.
As said, the rattle only occurs when coasting - and can be felt through the gear stick.
My first thought, with very limited car knowledge, was that this was a gearbox related problem. Does anyone have any ideas?
Thanks in advance
Threads: 386
87
It does sound like faulty diff bearings in the gearbox... Quite a common problem on the 1.4, I had it happen twice! I'd remove the drain plug on the gearbox and see if it's full of metal filings.
Threads: 87
48
Not as simple as exhaust fouling on the gearstick is it?
Threads: 386
87
Well if you've had a new centre pipe that's a good place to check lol!
If it is the gearbox, they cost about £50 used, about £150 labour if you're not doing it yourself. Also worth changing the clutch at the same time.
Threads: 1
Okidoke, thanks for the help guys - much appreciated. Will post again once I've got an update!
Threads: 476
81
Car Model/Spec: 306 Rallye
yeh check the exhaust. When the engine acceleerates it should twist backwards which will move the exhaust away from the stick. When costing it will go back to its original position. Does it rattle when idling and youre not driving anywhere?
