Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
Hi guys,
I have a stage 1+ map from pro steve. I also have a totally straight through exhaust. I'm wondering if I ever decide to go back to a quiet exhaust in the future will I need to drop back down to a stage 1 map? What issues can be caused using a stock exhaust?
Thanks, Jack
Why have you installed a straight-through exhaust?
Threads: 18
10
Mine's been running around on one of JP's Stage 1+ maps for about 35k miles now on an otherwise standard car. No problem.
Reminds me, I really must get around to sorting out that de-cat and exhaust...
Threads: 186
38
Car Model/Spec: MG ZR VVC
Putting on a mid pipe (resonator) shouldnt do much in terms of power as thats more for noise
Well all that stuff about back-pressure affecting spool times and top end flow is the answer lol.
Threads: 202
58
Go read your threads again, all of the information is there.
Threads: 128
21
Don't do it.. the recumbent pressure in the manifold screws will be too high if you have the stage 1+ and affect the rail sensor calibration and injection parameters.. if it's too badly affects these you will lift the turbo off of its mounts and start popping seals
/Toseland
Threads: 4
6
In all honesty it doesn't make a blind bit of difference to safety (all my maps are safe, and tested under extreme conditions), I only suggest it because you're not going to get the full 125 on the dyno unless you've got the free flow exhaust system.
The free flow exhaust helps turbo spool, reduces back pressure and generally gets more air through the engine so it's going to run cleaner with the stage 1+.
