Wanted: 205 bits
I know a few people have some 205s and bits lying around so i see if anyone 1 can help me out. A few bits im after for my 205.
Im after a rear parcel shelf, heated rear screen switch and the gear stick center bit that bolts to the subframe and is kind of a L shape. After 1 with a decent condition bush it is as mine is pretty wore.
I've got a heated window switch here.
Assuming you mean the L-quadrant part that pivots on the subframe, new bushes from Peugeot are pennies. I can get the part number if you need it.
Edit - just checked and the gear linkage L-quadrant bushes are part number 2175.05 and they're 41p each including VAT. You'll need two.
(20-11-2015, 04:26 PM)powerandtorque Wrote: I've got a heated window switch here.
Ok cheers, how much for the switch?
Ideal cheers, ill give them a call in the morning
I doubt they will sell you 2 as they come in packs of 10 or 20 from memory, If you need a couple I have them in stock at £2.95 delivered, Everything is sent recorded delivery
(20-11-2015, 06:20 PM)miles Wrote: I doubt they will sell you 2 as they come in packs of 10 or 20 from memory, If you need a couple I have them in stock at £2.95 delivered, Everything is sent recorded delivery
Ok may take you up on that, are they all the same? My 205 is a 1.8 diesel
£7.50 delivered for the switch.
I might have a couple of bushes spare, I'll check in the morning.
(20-11-2015, 10:19 PM)powerandtorque Wrote: £7.50 delivered for the switch.
Ok cheers, Ill drop you a message on whatsapp later on
powerandtorque sorted me out with the rear screen switch and gear link bushes.
Still after a rear parcel self if anyone has 1? Also think i need the gear rod from the gear stick to the subframe linkage if anyone can help? Though i may poss end up buying the full set of 3 off ebay. Think Miles sells them
