	Threads: 101
2 Location: Oxfordshire
 Car Model/Spec: 306HDi 90 LX
 Thanks: 13Given 28 thank(s) in 28 post(s)
		query;are there any rear shocks that would help the rear ride-height for towing/holiday luggage?
 I know the rear beam is going, and have a spare one ready to refurb when I've some spare cash, but i'd like 'something extra' for those odd occasions i'm carrying extra load.
It goes, it stops (as reqd).
Hate Housework!
	Threads: 465
114 Location: Cullompton Devon
 Car Model/Spec: Vauxhall
     Thanks: 1Given 98 thank(s) in 92 post(s)
		shocks will settle to where the springs/bars hold the car
 so shocks alone wont raise the hight of the car
87 Location: Suffolk
		The height is set by the bars and the lean of a dodgy beam, not the shocks, all stiffer shocks would do is make the rear end skittish over rough ground.  You need thicker TBs and a beam that isn't broken...
2 Location: Reading
 Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
 Thanks: 0Given 5 thank(s) in 5 post(s)
		You may want to consider an estate set-up, designed for heavier rear axle loads. Although, AFAIK the only difference is the thicker bars.
2001 BMW 330Ci2012 VW High Up
 1988 205 GTi 1.6
 1990 205 Mi16
	Threads: 101
		pity*. anyway, thanks guys!*(I recall older cars with coil or leaf springs had more options.)
Hate Housework!
		22-11-2015, 11:49 AM
(This post was last modified: 22-11-2015, 11:58 AM by Toms306.)
		Coil springs on the rear are a far better design as used on pretty much every other small hatch in the 00s...  Torsion beams are horrible and only fitted to save space, but at least the boot space is good on a 306...
	Threads: 101
		 (22-11-2015, 11:49 AM)Toms306 Wrote:  Coil springs on the rear are a far better design as used on pretty much every other small hatch in the 00s...  Torsion beams are horrible and only fitted to save space, but at least the boot space is good on a 306...
I agree with that (5pc drumkit or full pa system)
Hate Housework!
		Yeah I miss the boot space of the 306 estates.     Will probably buy a cheap one for my next house move I reckon haha.
I do not miss torsion beam suspension though!
	Threads: 101
		not tried one of them.
Hate Housework!
		There's not much that doesn't fit in them...  Every part on a mk4 Golf for a start lol, huge lumps of tree and bush (don't    ), the majority of my Nans cottage, etc, etc.  Never had to use the trailer once I had an estate, just used it for things like lawn mower to save mess inside.
	Threads: 61
3 Location: Glasgow
 Car Model/Spec: Phase 1 306 xsS
 Thanks: 20Given 21 thank(s) in 21 post(s)
		 (22-11-2015, 12:18 PM)Magenta Sunset Wrote:  not tried one of them.
Do it, they're great load luggers!
	Threads: 101
Hate Housework!
	Threads: 70
10 Location: Bedford
 Car Model/Spec: HDi Estate
 Thanks: 4Given 9 thank(s) in 9 post(s)
	Threads: 34
8 Thanks: 0Given 8 thank(s) in 8 post(s)
		 (22-11-2015, 12:29 PM)Magenta Sunset Wrote:  just found this via Google;http://www.springassisters.co.uk/31B09%20INST.pdf
They are good.. But you need springs for them to work lol
119 Location: Southampton
 Thanks: 13Given 106 thank(s) in 106 post(s)
		Get a late estate rear beam, they have thicker torsion bars and arb iirc.
	Threads: 101
		according to their spec, designed for torsion bars -http://www.springassisters.co.uk/menu.htm
will mull it over AFTER getting the beam sorted
Hate Housework!
	Threads: 448
51 Location: isle of wight
 Thanks: 17Given 18 thank(s) in 18 post(s)
		Yeah im not sure how those would work on torsion bars
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg) TEAM CONROD SHITTING RALLYE!
	Threads: 18
10 Location: Wiltshire
 Thanks: 3Given 17 thank(s) in 17 post(s)
		 (23-11-2015, 12:25 PM)Matt Wrote:  Yeah im not sure how those would work on torsion bars
Looks like it's a spring that fits between the trailing arm and the body, effectively increasing the spring rate.
	Threads: 55
17 Location: Rotherham
 Car Model/Spec: 406 V6
 Thanks: 3Given 10 thank(s) in 10 post(s)
		23-11-2015, 08:23 PM
(This post was last modified: 23-11-2015, 08:24 PM by Rippthrough.)
They're no better than the torsion bars.
For the 90th time, the rear of a 306 is NOT a torsion beam. That's fitted to shitty Fords/Kia's etc, to save cash, it works nothing like the rear 306 suspension. BEAM =/= BAR. Completely different systems.
Custom roll cages/shiny suspension bits/general fabrication work undertaken, PM me.Top engine mount repair/reinforcement/chocking for cracked chassis and high powered cars, drive in, drive out, 2 hour turnaround.
	Threads: 101
		is there a thread covering the differences? i'd like to learn.
Hate Housework!
	Threads: 55
		Could do with one, half the people on here still bang on about going fully independent at the rear too....
	Threads: 101
		23-11-2015, 08:36 PM
(This post was last modified: 23-11-2015, 08:53 PM by Magenta Sunset.)
		IRS? needs an old Jag or sierra I believe.
slightly off subject, best rear end I've ever had my spanners on was an SD1. Live rear axle, coil springs, Watts linkage.
Hate Housework!
		 (23-11-2015, 08:23 PM)Rippthrough Wrote:   (22-11-2015, 11:49 AM)Toms306 Wrote:  Coil springs on the rear are a far better design as used on pretty much every other small hatch in the 00s...  Torsion beams are horrible and only fitted to save space, but at least the boot space is good on a 306...  They're no better than the torsion bars.
Cheaper and easier to replace.
Cheaper and easier to lower or upgrade.
Doesn't give you a sideways bounce on rough corners.
Don't give you a twitchy arse on long sweeping bends.
Don't give LOOS if you run out of balls on a corner.
Don't give the terrifying 'roll' when you apply the handbrake and let off the footbrake on hills
I'll stick with coil springs any day...
	Threads: 101
		23-11-2015, 09:01 PM
(This post was last modified: 23-11-2015, 09:02 PM by Magenta Sunset.)
		Finally! got my picture to show up!
Hate Housework!
	Threads: 18
		Actually Tom, most of those "faults" aren't down to the basic torsion bar setup at all... but don't let that get in way of what you're saying or anything.
		A couple are down to old beam mounts if that's what you mean...but that's still part of the beam and not applicable to coil rears...
	Threads: 101
		here's a thought,
Nivomat type shocks for when towing (?)
Hate Housework!
	Threads: 55
		23-11-2015, 10:28 PM
(This post was last modified: 23-11-2015, 10:34 PM by Rippthrough.)
		 (23-11-2015, 08:53 PM)Toms306 Wrote:   (23-11-2015, 08:23 PM)Rippthrough Wrote:   (22-11-2015, 11:49 AM)Toms306 Wrote:  Coil springs on the rear are a far better design as used on pretty much every other small hatch in the 00s...  Torsion beams are horrible and only fitted to save space, but at least the boot space is good on a 306...  They're no better than the torsion bars.
 All of which is nothing  to do with having coil springs.
 And some of which are everything to do with f*cked/knackered parts.
I did do some rear dampers for 306's which had internal springs to boost the spring rate, but the price of them now would make most people think twice.
	Threads: 101
		i'm going to see what a refurbed beam will do before I do anything else
Hate Housework!
	Threads: 55
		 (23-11-2015, 08:36 PM)Magenta Sunset Wrote:  IRS? needs an old Jag or sierra I believe.
The 306 is already IRS
Yes, rebuilt beam and go from there, no point upgrading something that's already tired.
