Bmw E46 Diesel Project
#91
Haha you can see that it needs a wash in person the picture hides the dirt haha
#92
Got around to spraying the arches before my wedding last week, didn't look too bad for a first time doing bodywork....
Then Saturday night while at my wedding a group of w*****s thought it'd be funny to lift the rear end onto a hay bale and in the process put a big dent in my door [emoji35] leaving me with a £250 bill to get the dent pulled out
Now on Monday its due for MOT any common issues I'm likely to face bar the rubbish handbrake?
#93
Well she threw up a nice list at the mot
[Image: d557e0fddc327cdf54a2a301e13f3bf3.jpg]
#94
crikey, bit of a deathtrap then!
#95
How did you not notice some of that stuff lol!? Confused
#96
Tbh I knew about most of it but over the past few months I've had a wedding to plan and it's taken a back seat lol
#97
Loves that Renault too much.
Fair list but few days work should see it through.
Oil light though Dodgy
Got mine tomorrow but I'm hoping it'll go through as I cannot be dealing with 35MPG from the backup vehicle.
#98
(07-08-2015, 01:49 PM)mr_fish Wrote: Loves that Renault too much.
The Renault may have been having a little love recently [emoji56]
Oil light is only down to a dodgy sensor and not oil level though haha need to do it at the next service
Got a nice nad here if you need something reliable Wink
#99
(07-08-2015, 01:49 PM)mr_fish Wrote: Got mine tomorrow but I'm hoping it'll go through as I cannot be dealing with 35MPG from the backup vehicle.
Best hope you get a friendly tester Wink
Well after a lot of work this went through it's MOT today and it passed at long last
It's had
Both front wishbones and rear bushes
Both front brake hoses
Both front m sport shocks and springs
Both rear brake lines front to back
Both drivers jacking points cut out and welded up
Rear brake hose
Rear brake pads
Handbrake adjustment
New tyre
Cleared airbag faults
Next stop: . boost
FML got home from the MOT to a binding brake calliper smoking an awful lot lol
Take it back, whoever replaced your pads should have noticed the caliper was binding and sorted it out. It should also have failed the mot if it's binding that badly. Confused
(30-08-2015, 07:45 PM)Poodle Wrote: Take it back, whoever replaced your pads should have noticed the caliper was binding and sorted it out. It should also have failed the mot if it's binding that badly. Confused
Pads on the front haven't been changed lol I think I nicked the seal when I put them back on :oops: it seems to be a bit hit and miss with when it binds so will strip and rebuild them in the next few days
Ah fair one, bit random. What's going on with this anyway, do you have a different favourite car now? I saw that dirty word a few posts up....  TMI
Turbo is sat waiting to be fitted and hopefully should be a straight swap, want to knock up a decat aswell but I need to sort out some ££ for a map first so I can just slap it on over a weekend and it's drive able
Have to admit though it drives soo much nicer now lol
That sounds more like it! Big Grin It's amazing the difference it can make just replacing a couple of minor suspension parts.
Couple of pictures from the other day
[Image: f8ee123389c31c3e3db484467e6b6304.jpg]
[Image: 5f7bf24a13c2d2c2a31d2c945473e582.jpg]
[Image: 8f758ba838c4b0af124d63ab99985723.jpg]
This is not a good thing
Took me a sec.. whooops, that's hot!
Time for a caliper clean/replace I guess
Yeah new calliper on its way as of today lol and as always bad things come in 3s Saturday the central locking packed in and this morning I had a flat tyre [emoji20]
Not having much luck with this are you bud? haha
(13-10-2015, 08:41 AM)Midnightclub Wrote: Not having much luck with this are you bud? haha
Really not haha picking up again now though, Central locking is sorted just had to re-sync both keys, new calliper arrived today so that's on the list for Saturday along with whipping the exhaust off to check for any blockages and hopefully sorting the handling issue Smile
What's up with the handling bud? If you've not taken it for a 4 wheel alignment yet I'd strongly suggest doing so, makes a huge difference when it's all set right.
If it's a rear end wandering kind of feel, it could well be your RTABs (rear trailing arm bushes) - pretty easy to replace them with powerflex though
Front wishbone bushes go badly on these as well
Yeah, he has just replaced the wishbones I believe though. Although if the lollypop bushes are original they'll more than likely need changing.
Gotcha, sorry didn't read back through the thread
S'all good.
I take it you didn't have any further luck with INPA too tom?
(16-10-2015, 08:41 AM)Midnightclub Wrote: What's up with the handling bud? If you've not taken it for a 4 wheel alignment yet I'd strongly suggest doing so, makes a huge difference when it's all set right.
Issue I've got is one of the ARB bush studs has snapped off so it wanders an awful lot at the front end with its current temporary fix
I've got a pair of msport struts/springs that need fitting in the front before I go for alignment but definitely needs doing (y)
Both front wishbones and lollipop bushes have been replaced a couple months ago Paul Smile
And no more luck with INPA mate haven't really had time although did get the brake sorted out last night Smile
Ahh okay, that does make sense. Are the studs replaceable or is it a ballache?
Makes sense, should drive pretty well after an alignment and all the bits you've fitted/fitting. Was it a front or rear caliper that went, couldn't tell from the pic?
(19-10-2015, 11:53 AM)Midnightclub Wrote: Ahh okay, that does make sense. Are the studs replaceable or is it a ballache?
They are indeed a ball ache, needs to be completely drilled out and have a new one welded into the chassis
I'm hoping it will drive nice after alignment, it was a front one that went - was a small split in the piston seal so probably let some moisture in
In other news I had the exhaust off at the weekend and it sounded beautiful so will be straight piping it soon
http://youtu.be/BaJMB1GGTmQ
Also had a look and it seems that the vac can doesn't do anything at all currently so that is the next thing to look into as cause of the power loss - thank you Mr fish Smile
