Sprung vs un sprung.
#91
Will them groves help it hold in any way? Or just to make it look pretty? Ive fitted a luk kit to my zx think it'd be ok with just a pressure plate or would I be best with full kit?
#92
I assumer they may help dissipate heat a tad quicker. Wouldnt of thought they would hold any better though.
#93
Aren't they there to 'shave' the centre plate to stop it glazing with heat, like brake disc grooves?
#94
No.idea but there not worth the extra £100 expenditure lol
#95
Yeah the pressure plates are just grooved and paint valeo, valeo bearing too.
(15-08-2015, 11:20 AM)bashbarnard Wrote: No.idea but there not worth the extra £100 expenditure lol
Lol, I'm sure you could do the same with a dremel anyway... lol
#97
(14-08-2015, 07:44 PM)bashbarnard Wrote: Ah the second hand brand new one you bought. The right one looks like a standard jobbie painted black with grooves machined in.
Yeah the 1 on the right is the 1 i had issues with. It was painted but i painted it again so i could see where it was catching the the gearbox
#98
This ones just arrived
#99
Out of interest, could you measure the depth of the splines chap?
Looks to be possibly changed again, hopefully deeper to prevent the wear / noise issue!
[Image: sigi-2.png]
Yeah no problem
22mm by a tape measure. Thats all ive got at home so could be a little out. Can get the verniers on it tomorrow for a more accurate one if you want.
Also just a side note. Friction materials not very thick.
The 2 unsprung friction plates I have for an Xud are different. 1 looks the the same as you got
The one your running?
The xud just has a standard clutch ATM. Poss going to look into getting the re-plated though
My paddle been in a week now. Runs fine. Get the usual rattling on idle with the clutch but goes away when you press the pedal. Works fine and grips like mad!
...so far
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
So ive sent the clutch back with a spare input shaft i had lying about so they can rectify the mistake. I have been dealing with linda the entire time and she seems more than happy to help and the customer service has been good. Even said thankyou for me offering to send the input shaft so they could see the problem first hand. Although Yes there is an issue at this time. it is being sorted as we speak.
What is the issue? Play betwern the splines?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Yeah. Ill put a video up tonight and link it.
https://m.youtube.com/watch?v=C1bz0Xm4_Bo
Looks like im in trouble
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
(27-08-2015, 05:23 PM)ADV_93 Wrote: Looks like im in trouble
Oh dear. Is yours the same??
It rattles on idle. Or with clutch disengaged. Causes quicker wear or anything?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
I would assume so. Not good. Id expect a little rattle. Not a lot. Hows it holding boost.
Drives fine and holding but in barely pushing it atm. Only running a tiny GT20
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
That is the problem I was talking about regarding the width / quality of the spline, this seems to have been an ongoing issue for some time... It will cause extra wear and I guess eventually will wear thin enough / strip it and loose drive, although I'm yet to see this happen / have given several of the effected units some serious abuse!
Yet to decide on clutch for the bus, but until this issue is ironed out / resolved im going to hang fire / weigh up other options as its far from ideal.
[Image: sigi-2.png]
If any issues persist ill update.
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
So they've fixed it and its back!! Appears to have a sachs centre bit in now. Barely any movement on the splines. Can upload a video later if you guys want to see??
Great news, yes get a vid up. Hopefully this irons out the issue for future customers Smile
So here is a short video so you guys can see. not the best not being near a gearbox. for all the people that say cg dont have good customer service. i sent this to them last Tuesday after speaking to linda who dealt with my clutch the numerous times i rang. They got this turned around in five working days. obviously havnt got the clutch in yet. maybe next week now. But i would be more than happy to deal with them again.
https://www.youtube.com/watch?v=nq9NQZfP...e=youtu.be
Kinky Wink
(27-08-2015, 05:49 PM)ADV_93 Wrote: It rattles on idle. Or with clutch disengaged. Causes quicker wear or anything?
I have same thing
Piggy have you had any issues with yours? Are you also running the same unsprung setup?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
