	Threads: 210
1 Location: Bristol
 Car Model/Spec: Ph1 White Gti6/306 DTurbo
 Thanks: 19Given 7 thank(s) in 7 post(s)
		So looking to purchase my oil cooler ASAP but not sure if I should go for 13 row or 16. I'm getting it with a thermostatic plate so I don't have to worry about it not getting up to temperature. What would you guys recommend?
81 Location: Ipswich
 Thanks: 4Given 104 thank(s) in 102 post(s)
		is it the same as 306 ones? If so im also after one so please recommend people!
 Thermostatic plate is the best i believe as it allows the engine to warm up in the first place.
	Threads: 210
1 Location: Bristol
		 (28-07-2015, 02:31 PM)Eeyore Wrote:  is it the same as 306 ones? If so im also after one so please recommend people!
Yeah allows it to the right temp then opens up to cool it down
		 (28-07-2015, 02:34 PM)Nathan1305 Wrote:   (28-07-2015, 02:31 PM)Eeyore Wrote:  is it the same as 306 ones? If so im also after one so please recommend people!
Seems like a no-brainer!
	Threads: 79
17 Location: Stroud, Gloucestershire
		Thermostatic will open at 80, this seems too cold to me, would prefer it a little higher but no one makes one. As for recommendations i dont have any im afraid.
 Pointless post.
	Threads: 62
10 Location: Rugby, Warwickshire
 Thanks: 0Given 11 thank(s) in 11 post(s)
		28-07-2015, 06:28 PM
(This post was last modified: 28-07-2015, 06:28 PM by C2K.)
		Why? You'll have the stat open in no time driving normally, running it cooler keeps the oil from optimum temperature.
 Even my golf runs at 95 oil temp unless regenning the dpf. Rallye has a 19 row and sits at the stat temp..
Night Blue VW Golf 7 GTD : Bianca 306 Rallye : Mini Cooper D (The Mrs') ![[Image: wallye-gtd.JPG?raw=1]](https://www.dropbox.com/s/pcxk1pgpaucznvr/wallye-gtd.JPG?raw=1)
HDi Owner for 200k/9 years
	Threads: 186
38 Location: Manchester
 Car Model/Spec: MG ZR VVC
 Thanks: 3Given 21 thank(s) in 19 post(s)
		Also looking into oil coolers so will be keeping an eye
	Threads: 210
1 Location: Bristol
		 (28-07-2015, 06:28 PM)C2K Wrote:  Why? You'll have the stat open in no time driving normally, running it cooler keeps the oil from optimum temperature.
It's for my track 106 so will be getting pretty hot. Want to keep the oil at a good temperature to reduce failure due to oil pressure
	Threads: 62
		That was for the post ahead of mine.  You don't have a stat yet lol,  and I know why you want one.
	Threads: 210
1 Location: Bristol
		 (28-07-2015, 07:30 PM)C2K Wrote:  That was for the post ahead of mine.  You don't have a stat yet lol,  and I know why you want one.
Oh haha no ones answered my question still    I'm probably just going to get a 13 row it's good for 150bhp
	Threads: 58
5 Location: South west
 Thanks: 6Given 16 thank(s) in 16 post(s)
		I wouldn't bother with a stat I don't run one on my 205 stats are open a little all the time anyway.
	Threads: 210
1 Location: Bristol
		 (28-07-2015, 09:12 PM)Stef205 Wrote:  I wouldn't bother with a stat I don't run one on my 205 stats are open a little all the time anyway.
Oh okay so it should run fine temp wise. What's a good temp for oil? 90 degrees?
	Threads: 61
11 Location: Bury  St  Edmunds Suffolk
		28-07-2015, 09:35 PM
(This post was last modified: 28-07-2015, 09:37 PM by 7057sam.)
		I have a 16 row and stat atm on the astor
Had a 19 and no stat on the rallye.if don't drive it everday no stat's fine.obviously with no stat you have to wait that little bit longer till its warm as cooler is always on.
106 sub 150 bhp should be fine with a 13 row
  (28-07-2015, 09:33 PM)Nathan1305 Wrote:   (28-07-2015, 09:12 PM)Stef205 Wrote:  I wouldn't bother with a stat I don't run one on my 205 stats are open a little all the time anyway. Oh okay so it should run fine temp wise. What's a good temp for oil? 90 degrees?
Mine used to take best part of 20 mins to get to temp (driving mph roads and a little bit of 70's)
When warm should sit at 89 on road maybe peak at 100 on track.
	Threads: 58
		well the gf has a small 10 row on her 106 and that heats up fine as does mine. I wouldnt expect it to heat up any quicker than 20mins tbh
	Threads: 541
124 Location: Aylesbury
 Thanks: 7Given 59 thank(s) in 58 post(s)
		What oil temp are you hitting at the moment?
 On my HDi that had an oil cooler even with a thermostatic plate it never got past 70 which isn't hot enough. If your not struggling with temps then don't bother and spend your money elsewhere.
 The stats on the oil coolers are not like the one in your cooling system, even when "closed" they are still letting oil through as otherwise no oil would go through the filter so they do still slow down warm up times.
	Threads: 210
1 Location: Bristol
		Might just put my oil temp gauge in, give it some abuse and see what temp it comes back with
119 Location: Southampton
 Thanks: 13Given 106 thank(s) in 106 post(s)
		You'll need it on a revvy petrol track car, hdi is a completely different kettle of fish. Have you signed up to any of the track day forums?
	Threads: 210
1 Location: Bristol
		 (29-07-2015, 12:34 PM)Poodle Wrote:  You'll need it on a revvy petrol track car, hdi is a completely different kettle of fish. Have you signed up to any of the track day forums?
Not yet what forums would you recommend?
	Threads: 8
0 Location: Australia
 Car Model/Spec: xtdt 306
 Thanks: 0Given 1 thank(s) in 1 post(s)
 Country:
		29-07-2015, 02:55 PM
(This post was last modified: 29-07-2015, 02:56 PM by ozpug.)
		So I'm thinking out loud here. From my rudimentary knowledge of cars I thought cold oil is a positive. The main negative of cooler oil temperature being that it doesn't flow as well, putting more pressure on the pump and not flowing to important internal components. But isn't the engine and all internal components perpetually oil soaked, so the only negative being oil pump working overtime. Can this problem be negated by using a lighter weight oil?
 I can't remember why I think colder oil is better. Thermal efficiency? Less entropy?
 I've got a 16 row cooler on an xud9. Seems its probably not needed but I'll have to do some more reading now.
	Threads: 465
114 Location: Cullompton Devon
 Car Model/Spec: Vauxhall
     Thanks: 1Given 98 thank(s) in 92 post(s)
		you need oil at atleast 80+ to evaperate out the condensation that forms from cold starts
	Threads: 62
1 Location: South Wales
 Car Model/Spec: Megane 265 + SHB Gti 6
 Thanks: 1Given 6 thank(s) in 6 post(s)
		Seems the same in aircraft engines as well... 86deg constant moves 1 deg at most at 100% or 10%
		29-07-2015, 05:20 PM
(This post was last modified: 29-07-2015, 05:21 PM by Poodle.)
		No idea, i'm not on any of them lol. I was chatting to a guy who runs a business prepping track cars and he suggested i sign up to a couple when i showed an interest, reckoned there was a wealth of knowledge there. Just figured it might be more useful than the limited experience here.
