New Van project
New 1.6hdi van hate engine already
To do list
Building a xud
Hdi rods
Bosch with 11mm
Got big fmic
Was going to fit td04 but from what I read kick it to late
Got a gt17 saab turbo just bit bigger
Straight pipe exhaust
Bigger rad
307 hdi 6 speed need to make custom back mount and fit cable stick
Gti6 brakes
Change axle
Some alloys
And a good clean
Nice one. Just bought some gti 6 brakes for my van. Will follow this as interested to see how it goes
Sound interesting
Looks clean from the outside Smile
[Image: Cn91r40h.jpg]
Well looks like the van didn't want a clean my electrics going mad now lol. speedo cluster lighting up like a Christmas tree everything else on dash works and engine runs think I got something wet
[attachment=24246]
Nice new bigger steel wheels not full rust lol plus brakes will fit under
And some wind deflectors
You have to be careful with these. Basically i think they have the economy mode when they don't detect the engine running and puts all the ecus into shutdown. Which isn't a problem for the engine ecu but the bsi that runs all the electrics on the vehicle will be. Im just saying this as I was going to build a 207 xud not that long ago instead of my estate and came across this problem.
Already built one ecu just needs a sig from crank that also gives you a rev counter Big Grin
207 xud would be different lol
Fair enough man. How do you get the correct signal from a 1.6 though as the signal on the dv6 is taken from the crank pully and the signal from the xud is on fly wheel.
Just going to put my bsi/ecu from my old van with modified flywheel dw8 one
Would still take in out eco mode with 1.6 ecu but rev counter would probably not work right
Ah I see. Well best of luck my man.
Thanks mate
Have to get this done so taking some short cuts need it on road
Custom back mount made to take newer box 206 hdi but not 6 speed as still in 307 not had time to take it out. will fit later when I get time but with custom back mount will just be a straight swap
Saab gt17 mocked to make sure no clearance issues adapter plate made. Got 2 questions were best to plum the water feeds for turbo also between the adapter plate should I put some sort of gasket
Missing out hdi rods hope be ok lasted over 200k so far lol
That exhaust not staying like that lol
I ran a gt17 on my last xud. (Search my threads for ph3 xud)
I never plumbed in the water lines and it was absolutely fine
[Image: av5ym8.jpg]
took my van up the hill at pugfest today. was interesting on all standard suspension and brakes
(12-07-2015, 07:43 PM)Jimbo Wrote: I ran a gt17 on my last xud. (Search my threads for ph3 xud)
Thanks mate had a quick read that good work how was the gt17
(12-07-2015, 07:59 PM)Damo Wrote: took my van up the hill at pugfest today. was interesting on all standard suspension and brakes
Rub it in to much to do was planning to go Sad
Yeaah really good mate. Pulled 156bhp i think. Torque figure unknown as it had no rev counter for dyno operator to calibrate in.
[Image: av5ym8.jpg]
The faces of people when they saw a van going up was classic
Can't beat a sleeper lol
Some pics of work so far just cleaning and paint getting gaskets and seals tomorrow night so hoping to be in end week
[img][Image: 20150713_165150_zpscvgkmf8h.jpg][/img][img][Image: 20150713_161346_zpsvduk7ssp.jpg][/img][img=200x200][Image: 20150713_143043_zps296ftd51.jpg][/img][img][Image: 20150713_165138_zps4wxwuvp5.jpg][/img][img][Image: 20150713_165130_zpsbfxlmaie.jpg][/img][img][Image: 20150713_143039_zps07fot3dy.jpg][/img][img][Image: 20150713_175740_zpsx3xgnfg0.jpg][/img][img][Image: 20150711_131636_zpscjfmvidr.jpg][/img][img][Image: 20150712_163531_zpsmwd8hfi5.jpg][/img][img][Image: 20150713_143053_zpss5ws4jvc.jpg][/img][img][Image: 20150711_123052_zpsdahivrvz.jpg][/img]
(10-07-2015, 05:50 PM)xudlingo Wrote: Nice new bigger steel wheels not full rust lol plus brakes will fit under
Hay like the van
[img][Image: 20150714_213116_zpsnxivthmf.jpg][/img][img][Image: 20150714_162152_zpsodgwx1tr.jpg][/img][img][Image: 20150714_163450_zpsz3sc2esz.jpg][/img][img][Image: 20150714_171941_zpswk9lx8uv.jpg][/img][img][Image: 20150714_153111_zpst6z7vvo2.jpg][/img][img][Image: 20150714_163754_zps440lyugl.jpg][/img][img][Image: 20150714_163746_zpsx1dvjgwe.jpg][/img]
Nice day today so got lots done out with the new in with the old lol
Nice new bits fitted to engine xud engine mount not sitting right so all mounts now dw8 ones
Was worried about space at back and don't know why plenty
Thanks mate
All dw8 month now on and in the bay no nasty noises from mounts this time. Forgot that it was a dw8 timing belt I needed and got a xud one oops
[img][Image: 20150715_162416_zpsy5xfxqqi.jpg][/img][img][Image: 20150715_145725_zpsygwpfrxe.jpg][/img][img][Image: 20150715_145736_zpscysu0nmr.jpg][/img][img][Image: 20150713_175740_zpsx3xgnfg0.jpg][/img][img][Image: 20150715_145714_zpsivdvw8gb.jpg][/img][img][Image: 20150715_145707_zpsej8rhfij.jpg][/img]
Should be a runner tomorrow Smile
