	Threads: 177
		check the cables dont have any tight bends in them, and the clutch will be the white bushes that hold the release fork, spray the top one with wd40 then drill a small hole in the botom one and fill it up to
	Threads: 171
46
		Clutch is notorious for drying out and going stiff on them just because peugeot in their infinite wisdom when converting lhd to rhd decided to route the clutch cable right by the exhaust
	Threads: 18
		Just spray the clutch arm on the gearbox with loads of WD40 and then work it in. Mine was massively stiff (giggidy!) when I got it, just worked it in and loosened off!
1st - Diablo 306 1.9 N/A Diesel - Failed Gearbox
2nd -  Diablo 306 1.9 N/A Diesel - At 225,000 miles the engine fell out
3rd - Diablo 306 Sedan 1.9 Turbo Diesel - Rust bucket
4th - Cherry Red 306 Sedan 1.9 Turbo Diesel - Crashed 6 days after buying, Bah!
	Threads: 169
91
		As said above, my clutch was horrendous, just worked on it with some spray lube and a crowbar on the clutch arm. As for the accelerator, take the cable housing off and spray some white grease or similar down it, then put it back on, should sort it out. Perhaps a splodge of lubricant on the pedal (unlikely it will be this but will help a tad, if nothing else...)
	Threads: 55
17
Car Model/Spec: 406 V6
		Bushes + cable for clutch, sounds like the cables fooked on the accelerator too, try some wd on the spring on the throttle body first though.
