11-06-2015, 12:01 PM
(This post was last modified: 11-06-2015, 12:03 PM by Poodle.)
It'll be easy with two mate, will need at least four if you don't want to mark the tarmac dragging it about though.
Edit: hmm, just reread that, lifting it all the way over the engine will be a struggle, better off chopping out the front crossmember and pulling the shell backwards.
Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
Not sure on weight but when I scrapped my old DT we cut up the shell into 3 pieces, then my dad and I were able to lift each piece onto a truck he'd borrowed from work which was probably chest/shoulder height.
So 4 guys could lift a whole shell I guess. Why not just get 2 to lift the front up then drag the pallet with the engine forward and out the way?
Threads: 541
124
Depending on if you have doors wings boot etc you could still be talking 500kg easily.
I got £23.something for my bianca shell but I forget at what price so that's probably irrelevant but that was a bare shell.
Threads: 448
51
Yeah problem is with jacking it up I still can't just slide it out as the cross member is in the way! Absolute ball ache as I don't have an angle grinder here! Might have to go buy one again :/
Threads: 541
124
You'll go through the cross member with a hack saw.
If you get 2 scaffold poles you may be able to jam them in the chassis legs and get enough leverage to slide the engine out from underneath.
It'll let go if you apply yourself with a hammer, if you're that short of tools lol.
Threads: 541
124
^^^ Yeah several people on this forum have seen me scythe through cars with a maul, definitely the too of win.
