	Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
		Hi all,
Am I right in thinking that to replace the injectors on my car I need to find a set of these ones 0445110076 so they don't rattle.
Then I need to remove the fuel pipes. Pull the injectors out (Will I need a tool for this?) And then replace the copper washers and fit the new ones in?
Once it's all back in and connected they should just work shouldn't they?
Thanks, Jack
		There's a few threads on this recently, have a look around this section.
	Threads: 34
8
	Given 8 thank(s) in 8 post(s)
		Some 076s still rattle.. They are just newer so less likely too.
Youll need a socket to undo the injector clamp, cant remember size though ans hopefully theyll come out easy
	Threads: 11
Car Model/Spec: 306 HDI Stage 2
		Pretty sure they don't need coding. But someone will be along to confirm that.
	Threads: 21
Car Model/Spec: 306 hdi / rs turbo cabriolet
		As tom said clamp nuts 13 mm metal fuel pipes 14 mm
	Threads: 12
Car Model/Spec: Stage 3 306 HDI
		Did mine the other day from the engine which I took apart. Best to try and get them out when the engine is warm, mine came out pretty easy!
	Threads: 186
6
		Well I changed my injectors to the 076 ones. The rattle has become a bit less noticeable, itt seems to run smoother and pull better. One strange thing I have noticed as well is the revs seem to drop a little slower when I change gear. Before when I pressed the clutch in the revs would drop really quick and unless I threw it into gear really fast it would jolt as I let the clutch up but now when I press the clutch in I have more time to change gear so gear changes are much much smoother when I'm not rushing
