	Threads: 374
38 Location: Isle of Wight
 Car Model/Spec: GTI 6
 Thanks: 8Given 16 thank(s) in 14 post(s)
		In tradition; the, "What have you got left to do" before the next big show (FCS/Pugfest)
 I'll get the ball rolling:
 1) New tyres all round
 2) DD headunit to find, buy and install
 3) Remap to 255/265
 4) De-tar/De-sap , wax, minor detailing to paintwork
	Threads: 87
48 Location: South Yorks.
     Thanks: 2Given 74 thank(s) in 70 post(s)
		Everything and nothing........whatever I get time to do lol, car should get me there as is
81 Location: Ipswich
 Thanks: 4Given 104 thank(s) in 102 post(s)
		Jesus christ....
 New battery
 Replace Heater Matrix
 Fit Refurbished GTI Rear Beam
 Fit Rear GTI6 ARB
 Fit Solid Rear Beam Mounts
 Fit Baker BM Engine Mounts
 Fit Wrapped GTI6 Exhaust manifold, magnex decat and magnex exhaust.
 Fit Seam Welded Subrframe (remove from estate)
 Fit Meyle HD Wishbones (remove from estate)
 Fit Lower Strut Brace
 FIT GTI6 ARB
 Fit GTI6 Sump
 ReFit Shortshift
 Full Service
 Refurbish Fondmetal 4000s
 Fit Spoiler
 Send Coilovers off for machining or fit standard top mounts again.
 Braided Brake Lines
 Paint plastic trims
 Paint Beam
 yeh... I think I win... If anyone is building an entire 306 from scratch then I must be second...
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		Fit air box and pipe up
Paint some engine bay shiny bits
clean moss off of car where it has stood so long
Fit new splitter
detail and wax car
Have wheels refurbished after someone kerbed one
54 Location: Cotswolds
       Thanks: 22Given 68 thank(s) in 68 post(s)
		12-05-2015, 08:49 PM
(This post was last modified: 13-05-2015, 07:40 AM by Piggy.)
		1) cut and fit all the polycarb windows.2) fit and trim and "wrap" fibreglass bonnet
 3) fit and check clearance for track wheels
 4) wheel alignment
 5) build new exhaust.
 6) fit new exhaust
 7) build new manifold
 8) fit new manifold
 9) fit new turbo
 10) fit some ninja fueling mods
 11) see "10" fail and try something else
 12) retune Arduino...a lot.
 13) test and setup brake bias
 14) finish brake lines and clasps
 15) fit and pipe in EMP gauge
 16) fault find and fix EGT gauge
 17) flock final parts and fit
 18) paint damaged parts
 19) fit frenchyness
 20) adjust suspension again
 21) finish strut brace, fit
 22) build harness bar and fit
 23) CLEAN a lot
 24) tidy engine bay
 25) polish all the metal parts
 26) polish all the outside bits
 27) secure battery
 29) service
 30) fit new driveshaft seals
 31) fit new breather pipework
 32) secure new air filter
 33) fit oil cooler
 34) remove oil cooler after the oil line explodes
 I'll add more when I remember it!
	Threads: 128
21 Location: Cardiff
 Thanks: 1Given 41 thank(s) in 38 post(s)
		new turboremap stage2+
 win
Given the choice between Niall and the sheep. I would choose the sheep!/Toseland
	Threads: 87
		I'll make her shine like a diamond in a goats ass inside and out but other than that life's keeping me too busy for big bines and such tings
	Threads: 127
33 Location: London
 Car Model/Spec: ZX Volcane TD
 Thanks: 6Given 32 thank(s) in 32 post(s)
		as always, try not to kill it
	Threads: 186
38 Location: Manchester
 Car Model/Spec: MG ZR VVC
 Thanks: 3Given 21 thank(s) in 19 post(s)
		Fit sportscat/decat or coat current system in pasteFit coilovers
 fit grooved brakes
 fix squealing noise
 make rear strut brace
 deep clean
	Threads: 45
3 Location: west sussex
 Car Model/Spec: phase 2, stage 2, gti 6.
 Thanks: 8Given 6 thank(s) in 6 post(s)
		Tax.insure
 mot
 fit oil cooler
 clean exterior
 polish engine
 oil change
 re paint a few bits and bobs
	Threads: 541
124 Location: Aylesbury
 Thanks: 7Given 59 thank(s) in 58 post(s)
		NSR tyre, 3 brake pipes, lots of cleaning, un tint NSF window, peg in boot carpet, lots of bits to tidy up with some fresh paint, new plates and re build the front end as it's getting some shinyness.
	Threads: 100
12 Location: Portsmouth
		13-05-2015, 11:41 AM
(This post was last modified: 13-05-2015, 11:41 AM by Pompey306mark.)
		Roll up in my borrowed clio as there is no hope my car will be finished in time, if I find the time to come to either show.
	Threads: 371
29 Location: suffolk
 Car Model/Spec: ford fiesta
   Thanks: 4Given 82 thank(s) in 82 post(s)
		Tape up a bit of wiring. Cleaning. I was prepared.Helping SRowell with his 1.8.
On a break from 306oc for personal reasons. If anyone needs or wants me most of you have my number and or facebook messengerThanks for the good times guys n gals. I might be back. Who knows.
	Threads: 61
11 Location: Bury  St  Edmunds Suffolk
		Get bash to weld up my exhaust,job done
	Threads: 15
2 Location: prescott hill
 Car Model/Spec: XSi
 Thanks: 2Given 18 thank(s) in 17 post(s)
		Fix brake wobble with new bearing/hub
Fit oil cooler
Might around to wrapping the car. Had the material for ages now!
Not doing fcs, next event is combe sprint 13/06 followed by track day there on 19th. Bought Pugfest tickets
P1 XSi track car2.4 LWB T4
	Threads: 210
1 Location: Bristol
 Car Model/Spec: Ph1 White Gti6/306 DTurbo
 Thanks: 19Given 7 thank(s) in 7 post(s)
		Try not to sell it and get an estate....
	Threads: 141
35 Location: Herefordshire
 Thanks: 3Given 14 thank(s) in 14 post(s)
		Fit hybrid rear arbpaint inner wings and slam panel
 refit new radiator
 gut all the remaining aircon pipes and fit rallye aux belt setup
 fit large pile of powdercoated engine parts and brackets
 fit EPAS setup
 stud conversion for the new wheels
 refit front bumper with extra bracing for the underside
 fit slimline fans and oil cooler
 braided fuel lines
 weld blowing exhaust midbox
 suspension regrease and spanner check
 full deep clean inside and out to remove 6 months worth of dust
Current stable '09 Mercedes E320cdi wagon
	Threads: 465
114 Location: Cullompton Devon
 Car Model/Spec: Vauxhall
     Thanks: 1Given 98 thank(s) in 92 post(s)
		wash, polish, nut and bolt check,  Load and roll
	Threads: 183
20 Location: eastwood/notts
 Thanks: 0Given 8 thank(s) in 8 post(s)
		TaxMot
 Gut the interior
 Fit bucket seats
 Fit harness
 Sort exhaust properly
 Make a Decat
 Finish filling, sanding and painting the rear dent.
 Fit quick shift
 Fit baker bm linkages
 Fit fiberglass bonnet
 Fit aero catches (bonnet and boot)
 2 new tyres
 Fit rear bumper
 Paint and fit Solid rear beam mounts
 Paint calipers
 Paint wheels
 Buy side skirts
 Change oil
 Remove sunroof
 Hopefully fit my vibra technic lower mount instead of powerflex mount.
 Wash
 Wax
 Hope for the best.
#2 Moonstone Blue HDI ![[Image: 6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg]](http://i512.photobucket.com/albums/t326/kent16_2008/6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg)
	Threads: 19
12 Location: Devonshire
 Thanks: 4Given 25 thank(s) in 24 post(s)
		Fit engine and deal with all associated issues.
	Threads: 31
4 Location: directly above the center of the earth
 Car Model/Spec: tu5 bitza/cherry dt
 Thanks: 2Given 5 thank(s) in 5 post(s)
		Build the lot, looks like I'll be coming in the workhorse if I can get the time off
	Threads: 266
18 Location: Somerset
 Car Model/Spec: 205 DTurbo
 Thanks: 73Given 7 thank(s) in 7 post(s)
	Threads: 102
18 Location: Warwickshire
 Thanks: 0Given 22 thank(s) in 22 post(s)
		14-05-2015, 04:54 PM
(This post was last modified: 14-05-2015, 04:56 PM by RetroPug.)
		This is before Pugfest:
Track Rod Ends
Droplinks
Refit a few bits on the underside eg. spare wheel, heatshields
Remove cat, get welded and refit cat & exhaust
Discs and Pads all round
Flush brake fluid
Remove side light bulb from inside headlight
Drive to settle new suspension and bed in brakes
Very good clean
Probably refit headunit that I took out to go in the daily
Still a load more things to sort out but that's the realistic list for before then, given that I usually don't have weekends free and maybe 1 evening a week if I'm lucky, plus the odd 1-3 hours over a weekend. Will hopefully have a weekend or two in June though!
	Threads: 1
 Car Model/Spec: Supercharged Gti 6
		Fit engine
Fit intercooler
Fit oil cooler x2
Wire and plumb it all back in
Fit and wire swirl pot and bosch 044 pump
Clean the car
Mot
Tax
Get breakdown cover
Actually make it to pugfest
