02-05-2015, 05:50 PM
Ever since I passed my test I've pretty much always had big diesel cars with loads of torque and loads of spec.
I fancy something a bit different to have for the weekends and track days but also went to keep it OEM+.
I want something a bit like a 205/306/106 Rallye. Something lightweight with just the essentials and with a bit of go.
My Missus has had as 2005 KA Collection for the last 4 years and the master cylinder failed a month or two back. She lost confidence in the car and we got her something else. I am now using the car as a base for a build.
I took this about 18 months ago. It had a new clutch and a SportKA gearbox fitted.
We've had the interior out about the same time and the floor was totally solid...
So the master cylinder was goosed. You had to constantly pump the pedal or it would fall to the floor.
Unfortunately when trying to remove the master cylinder one of the pipes was rather seized in place and had to be cut off.
Installed the new master cylinder & brake line.
And proceeded to snap a bleed nipple. :frown:
The nipple looks like an M6 thread which I cannot find in a motorfactors anywhere. :evil:
I made a bit of a cock up with the master cylinder.
There is a rubber O ring that sits between the servo and the master cylinder that I forgot to refit and had a massive vacuum leak.
Had to syphon out the brake fluid. Remove the master cylinder and reinstall with the new O ring.
And back together and running sweet again!
Unfortunately there is still the matter of the snapped bleed nipple.
Removed the wheel cylinder to try and extract the broken bleed nipple but it was too tight.
This is what the car is like currently.
There's two small patches of rust unfortunately. First is the filler cap which is going to need to be cut out and a replacement welded in.
Second is the sill on the O/S rear seems to have gone. I've actually pulled a fair bit off here, just fell to dust in my hands.
So plan?
1) Get the rear brake cylinder fitted and back on four wheels. Bleed brakes.
2) Get the car down to a welder to have the two patches above sorted.
3) Clean and under seal the entire underside.
4) The current 13" alloys are buckled. I plan to replace them with Citreon C5 15" hybrid steel/alloy wheels which are tough and weigh just 4.7kg each.
5) Respray the entire car. Planning on single stage vauxhall flame red. Easy to spray, easy to repair and easy to sort any blemishes and no lacquer!
6) Strip the interior and rebuild getting rid of any unnecessary features. Central locking, electric windows and air conditioning will be gotten rid of. Also going to thin the wiring loom of any unnecessary cables. Any sound deadening to be removed and the standard carpet and seats to be refitted to retain an OEM look. At this point I'll spray any visible interior paint red.
7) Clean up the engine bay of any unnecessary features and wiring. Power steering and aircon pumps to be removed along with anything else associated. Should also free up a few more HP.
8) Make it handle! New standard shocks to be fitted with lowering springs. Going to fit polyurethane bushes all round. Going to fit front and rear strut braces. Rear axle spacers to widen the track (If Citroen wheels allow?). Also want to fit a manual rack and steering column.
9) Make it stop! Not sure weather to just fit Sporka brakes or to go all out and fit 300mm Mondeo items. The car will be lighter than a standard SportKA and afraid without ABS the KA will lock the 300mm brakes too easy.
10) Make it go! 1.6 SportKA engine with an induction kit, Steve Wyndham racing cam & exhaust manifold along with an aftermarket catback exhaust and a remap. It should be ~120bhp.
Going to try sell what I can off the car that isn't needed to try help fund the performance parts. Don't want to throw money into this. Planning on using second hand parts where I can or parts that will hold their value.
Bailes.
So plan?
Bailes.
