Threads: 0
45
(14-04-2015, 01:26 PM)Niall Wrote: (14-04-2015, 09:24 AM)JJ0063 Wrote: SDS ftw
Why on earth would he need to use a SDS drill for drilling out bleed nipples?
He's already said he's using SDS drill bits and they aren't touching it, I didn't clarify whether I was suggesting an SDS drill or just using an SDS bit.
Threads: 169
91
Given 1 thank(s) in 1 post(s)
(14-04-2015, 01:55 PM)JJ0063 Wrote: (14-04-2015, 01:26 PM)Niall Wrote: (14-04-2015, 09:24 AM)JJ0063 Wrote: SDS ftw
All SDS (Slotted Drive System) is referring to, is the manner in which the bit is attached to the chuck. How would this impact upon a drill bits ability to cut through a material? The only factor I can think of would be if the bit was slipping in a 'traditional' chuck.
Time to buy some sharp, decent drill bits
Threads: 0
45
(14-04-2015, 02:22 PM)Grant Wrote: (14-04-2015, 01:55 PM)JJ0063 Wrote: (14-04-2015, 01:26 PM)Niall Wrote: (14-04-2015, 09:24 AM)JJ0063 Wrote: SDS ftw
http://www.technologystudent.com/pwtol/drill4.htm
James hasn't gone into detail on whether or not it's the drill or the drill bit which is struggling. Of course he is going to need a decent drill bit, but also a more meaty drill may be needed.
Threads: 591
54
Im using pretty decent cobalt metal drill bits, its not slipping in the chuck.
I have ordered a new set though as these are over a year old and i give em abuse
In other news...
a billet wheel, some laser cut flanges and pieces of lexan and fibreglass have now been ordered
Threads: 100
12
Car Model/Spec: 306 dturbo Ultra Spec
Billet fly? I have one of these to fit to mine.
I really want to get in on your fibreglass bonnet deal, but can't at the moment.
I was surprised with the weight of the car, I thought it might of been less. But like the progress you are making.
Threads: 591
54
Brakes bloody brakes.
Replacement pair of rear calipers to go on.
The right hand nipple broke
[attachment=22725]
New ride height at the rear
[attachment=22726]
Threads: 541
124
You don't have much luck with nipples do you.
Threads: 591
54
[attachment=22738]
Starting to look the part...
Need a bit more poke though
Threads: 183
20
Given 8 thank(s) in 8 post(s)
He must twist the nipples too hard!
Threads: 120
35
Car Model/Spec: Rallye/S16 & 175 megane
Given 40 thank(s) in 40 post(s)
Look at that heavy and unnecessary front splitter!
![[Image: 17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg]](http://i143.photobucket.com/albums/r143/matt-taylor/17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg)
Team Cyril
Threads: 591
54
28-04-2015, 05:40 PM
(This post was last modified: 28-04-2015, 05:48 PM by Piggy.)
so got some shiny stuff, which you will know if following on instagram.
Stripped the spare GTB down this evening. Need some new vane housing bolts which are made of nothing by cheese annoying and didnt come in the rebuild kit from Turbo Rebuild company up north.
Anyway, heres the old comp wheel next to the new one
[attachment=22869]
[attachment=22870]
Note, the extended tips down the shaft and width at the base slightly. Its lighter, only by about 3-4grams, but every gram counts towards that 1 tonne target
After a lot of calculations with a LOT of Ruans help, and lots of googling (how ruan fits all that info in his head is mind boggling) I came to the 6+6 blade rather than 11blade. This is going to be the limit really of the GTB20. But I would love to see if she will blow 250. But a more reliable 225bhp will be pleasant.
I'm not replacing the bearings as they are good and original, only done 40k, which no doubt the kit wont have as good bearings. But the oil seals on these are a weak point imho, so they will be replaced.
In other news, the repalcement windows have arrived, I got a puncture (0psi) but didnt realise till I drove it as you cant tell due to no weight in rear
but she drives real nice. Fresh brakes, a bias, wider tyres, thicker rear ARB and low weight really make for a lot of fun.
Arduino also close to being redone. Managed to get it running off the car 12v now without interference.
Next: custom manifold, new exhaust, new FG bonnet too. Lets hope I can get it all done for FCS
still need 16" rims for my track tyres
new arduino coolness
[attachment=22871]
Threads: 371
29
Car Model/Spec: ford fiesta
28-04-2015, 06:37 PM
(This post was last modified: 28-04-2015, 06:38 PM by bashbarnard.)
Looking good man as always.
Any luck with turbo being balanced
Threads: 541
124
Good to hear the arduino is almost fully working after 18 months of trying or however long it's taken you to sort it all out.
Threads: 591
54
It turns out it was the car wiring after all basically. But hey ho.
And after more research, and asking round...no balancing. The shaft and turbine is balanced independently from the comp wheel, and the billet wheel comes balanced.
In a ideal world once built up it be VSRd but no one will do it
Threads: 6
Car Model/Spec: 406 2.1td
Piggy well, waiting to see the new GTB working.
Threads: 591
54
01-05-2015, 08:54 AM
(This post was last modified: 01-05-2015, 08:57 AM by Piggy.)
want to know what £35 gets your from Peugeot....
[attachment=22927]
Oh well. Hoping these will stop my weeping oil leak. Breather pipes and some O rings for the filler connector.
Started some work on my custom dash...
[attachment=22928]
[attachment=22929]
won't be staying shiny, flock will make a return
Bits arrived for turbo too, so by end of weekend I hope to have the dash finished and turbo finished.
Oh and a certain David Beckett on FB was a genuine supernova star and sent me a load of manual window mechanisms inc a drivers one which ozone said he had....but was a passenger one  He sent them all for free, what a lad.
So I hope to start the polycarb windows too this weekend if it stays dry.
Then its exhaust/manifold time.
Then its panic time.
Threads: 541
124
Oh I know what that long hose is, block to head breather. Had to change mine and they are a PITA to do ended up cutting the old one in half to remove it.
Threads: 30
5
Car Model/Spec: 306 HDi Dturbo 5dr
Country:
David Beckett is a legend, we were best makes through primary and secondary school and his mechanical knowledge is very useful
Generous guy and good to know
![[Image: 9fa12c59-0c3d-4413-968d-6a7840ff068f.jpg]](http://i693.photobucket.com/albums/vv295/highwayman306/9fa12c59-0c3d-4413-968d-6a7840ff068f.jpg)
Threads: 591
54
(01-05-2015, 09:07 AM)Dum-Dum Wrote: Oh I know what that long hose is, block to head breather. Had to change mine and they are a PITA to do ended up cutting the old one in half to remove it.
think mine may just fall to pieces as i pull!
The other one is that nasty elbow behind the starter motor
Threads: 127
33
Car Model/Spec: ZX Volcane TD
rear bias valves finally, did you go for adjustable in the end? this thing actually on the road and drive able atm?
Some pretty exciting stuff in the pipeline then, nothing more exciting than turbos, manifolds and gauges
What material are you using for your custom dash panel, is it flexible?
Want to change out the stuff i used for my gauges, and tidy up the others with something similar - but I used perspex last time which is pretty brittle
Threads: 465
114
Car Model/Spec: Vauxhall
piggy what are the top two boards?
have you a link to where you bought the electronics kits??
Threads: 591
54
01-05-2015, 04:22 PM
(This post was last modified: 01-05-2015, 04:24 PM by Piggy.)
(01-05-2015, 10:26 AM)zx_volcane Wrote: rear bias valves finally, did you go for adjustable in the end? this thing actually on the road and drive able atm?
Yeah adjustable.
I'm driving it as usual tbh, cable ties and wire holding stuff in  drive it every other I guess.
She drives a peach but annoyingly only got 1.5bar as I don't wana risk hurting anything running on the boost can and with no gauges to keep an eye on stuff. Can't wait to get arduino back in operation.
Nah I'm using perspex acrylic too, easy to work with and cheap. It is brittle though as you say. I'm hoping it will be ok :blink:
(01-05-2015, 01:20 PM)cully Wrote: piggy what are the top two boards?
Just adjustable voltage reg boards, ebay seller in UK. I can find the link if you need??
Threads: 591
54
01-05-2015, 07:34 PM
so this is what 20+ hours of work on a custom half dash looks like....goodness it takes so much time to do custom bits!
[attachment=22946]
[attachment=22947]
leave it to cure overnight...lets hope I didnt miss any bits  knackered now.
Threads: 102
9
piggy why you doing that with the dash? make a one out of card board and paper mache for weight saving.
Threads: 591
54
Too much effort, its pretty light as it is, tough enough doing little bits for gauges custom, let alone the whole damn thing.
Threads: 102
18
I bet that will look really good. The flocked dash bits I had off you look great.
Threads: 591
54
[attachment=22961]
[attachment=22962]
Threads: 371
29
Looks the part. I'll give you that.
Threads: 183
20
Looks loads better now.
Threads: 127
33
brapp
looks good
forgot about heater controls, thought you'd gone for many more gauges
