23-04-2015, 09:49 PM
		What battery would be best for a HDI? Not sure about all the types and stuff :/ cheers
					Batteries
		23-04-2015, 10:23 PM
		biggest that fits the box, 075 iirc.
		23-04-2015, 10:32 PM
		Use your reg on ECP, it'll show the batteries that are the right spec.
		23-04-2015, 10:36 PM
		Cheers Welshpug! Tom ive tried that but just not sure what half the number and stuff mean
		23-04-2015, 10:42 PM
		Use google to check what they are then lol...  Mostly bigger numbers are better...  Higher CCA is always good.
		As Tom said, just google it. Incase you're too lazy to even do that, i've done it for you http://bit.ly/1EjZx0z
		24-04-2015, 05:05 AM
		Ah is how much power the battery physically holds. Theoretically on a 65ah battery you could draw 65a for one hour. Ah (amp hour) Cca (cold cranking amps) the amount of amps the battery can throw out for a short period of time. The higher the better with both really tbf. Less chance of flat battery and better cold starting   (24-04-2015, 05:05 AM)JTaylor2005 Wrote: Ah is how much power the battery physically holds. Theoretically on a 65ah battery you could draw 65a for one hour. Ah (amp hour) Cheers! Thats what I was looking for   Repped
		24-04-2015, 07:17 AM
		Peugeot 306 (Facelift) 2.0Hdi Diesel  2001 	– 	HIGHER SPEC 027T 	RECOMMENDED 027 Battery Code 027T, Voltage 12, Ampere – Hour 62, CCA550, Lx243, Wx175, Hx190, Kg16, STD Din Post terminals, Battery Code 027, Voltage12, Ampere – Hour 60, CCA540, Lx243, Wx175, Hx190, Kg16, STD Din Post terminals, autodata list the HDI battery as a RC 12 Ah, Ampere-hours (A·h) is a measure of electrical charge that a battery can deliver. This quantity is one indicator of the total amount of charge that a battery is able to store and deliver at its rated voltage. Its value is the product of the discharge current (in amperes), multiplied by the duration (in hours) for which this discharge current can be sustained by the battery. CA, Cranking amperes (CA), also sometimes referred to as marine cranking amperes (MCA), is the amount of current a battery can provide at 32 °F (0 °C). The rating is defined as the number of amperes a lead-acid battery at that temperature can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12 volt battery). CCA, Cold cranking amperes (CCA) is the amount of current a battery can provide at 0 °F (−18 °C). The rating is defined as the current a lead-acid battery at that temperature can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12-volt battery). HCA, Hot cranking amperes (HCA) is the amount of current a battery can provide at 80 °F (26.7 °C). The rating is defined as the current a lead-acid battery at that temperature can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12-volt battery). RCM or RC, Reserve capacity minutes (RCM), also referred to as reserve capacity (RC), is a battery's ability to sustain a minimum stated electrical load; it is defined as the time (in minutes) that a lead-acid battery at 80 °F (27 °C) will continuously deliver 25 amperes before its voltage drops below 10.5 volts. https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
		24-04-2015, 07:18 AM
		Thanks very much Cully, repped too
		24-04-2015, 05:11 PM
		In case you are wondering about brands, don't just go with a cheapy one. Most people think a battery is just a battery but far from it.  If you go to ECP, you will get either a Bosch or a Exide. I used to have a Bosch S4 and was severely disappointed. It failed within the warranty and i think a few on here have also have that issue. I had it changed at Halfords for a Yuasa and apparently they don't do Bosch any more due to the high failure rate. Surprisingly, for a cheap brand Exide normally last for years! Personally, i only use Yuasa batteries at work (not car batteries) and they are great. Never fail prematurely hence why I'm happy to have one on my car now
Team Eaton 1999 China Blue 306 GTi6 - Eaton Supercharged - 214.5bhp 181lbft
		24-04-2015, 05:18 PM
		Cheers Niall! Was thinking of getting a Varta one as thats whats currently on the car and its been good Although Yuasa rated very well
		24-04-2015, 05:22 PM
		Varta are also very good for cheap batteries. We use them at work for some of the smaller batteries and again, have no issues with them
		24-04-2015, 05:25 PM
		Yeah, Bosch are IMHO rubbish and don't deserve to be branded premium batteries. I've had no end of trouble with them. Go for an exide from ECP (444770276) or the Yuasa from Halfords. I don't know where you'd buy Varta from, but that'd be another decent option.
		Cheers lads Can get Varta from eBay at a good price Jonny
		24-04-2015, 05:56 PM
		i bought my new one from Battery i run a Hankook battery, was cheaper on there ebay shop, its 72AH and 610Cold Crank
		24-04-2015, 11:10 PM
		Exide have never let me down, using a 62/640 at the mo iirc.
		26-04-2015, 01:51 PM
		i have a HUGE exide one in the vitara, (its slightly bigger than the HDi one..)   and it had been sat for a good 3 months without being touched, (inside however) and was fully charged when i checked, and also turned over straight away, starting first time.. Its one of the Calcium ones (rather than lead acid) too, because of the angles the vitara was at when offroading. i also noted it seemed to start more easily with it as well compared to the other ok one i had in there. Given the choice between Niall and the sheep. I would choose the sheep! /Toseland |
