	Threads: 80
1
Car Model/Spec: 1999 306 Meridian 1.9 TD
		Slight issue in that my key wont go past position one in the ignition and i am stuck and hour away from home with no tools exept a couple of screwdrivers, a 13 mm socket and a 10 mm spanner, is there ANY way at all i can get it started? Its a 1999 1.9td with a lucas pump
Cheers!!
No smoke, No poke!
	Threads: 371
29
Car Model/Spec: ford fiesta
		Yes you cam get it started. But it would involve basically stealling your own car in a sense.
	Threads: 80
1
		No steering lock is off, how would one go about stealing their own car?
No smoke, No poke!
	Threads: 386
87
		XUDis easy to start...you'll have to get past the immob with a Lucas though!
	Threads: 26
2
Car Model/Spec: 306 xud twin turbo compound
	Given 2 thank(s) in 2 post(s)
		U could put a hot wire to the pump and then just cross the starter to get u home but no doubt ur pump still has the antitamer around the solinod so only other way out is pull the plastic off around the collum and get joining wires lol unless anyone else's cums up with sumthing :-) hopefully this helps
	Threads: 80
1
		Managed to get it started with the key somehow, cheers for the help!
No smoke, No poke!
	Threads: 591
54
		Get some oil in that key barrel!
