11-01-2015, 04:58 PM
[attachment=21082]
Whats this spare cut off lead?
[attachment=21082]
Pic isn't the clearest, but the only wiring around there is ABS, which I doubt Rallyes have?
Doesnt even appear to go anywhere!? It's not one of them static shock things people put on cars to reduce shocks is it?
11-01-2015, 05:11 PM
Apologies, not sure what is is
Rallyes have ABS yes Never heard of that shock thing before
11-01-2015, 05:14 PM
Why would you need to earth an exhaust?
11-01-2015, 06:17 PM
Difficult pic but i think your screwdriver is on the snapped exhaust earth strap. Ignore it tbh
11-01-2015, 06:24 PM
Thanks all, worth cutting off then?
11-01-2015, 07:13 PM
11-01-2015, 08:14 PM
Yeah its the exhaust earth strap, they have one for the mid section too.
11-01-2015, 09:33 PM
Is it even needed?
As said it's a ground strap.
11-01-2015, 09:56 PM
I've never had electrical problems with my exhaust without them.
11-01-2015, 10:10 PM
Can anyone explain what it does/did do? Not clued up at all on electrical stuff like this
11-01-2015, 10:24 PM
They are there to earth the exhaust to the body which has just made me realise something.
The exhaust has a very bad earth connection. Its held to the body on rubber mounts and its only contact with the engine is a poorly fitting wire metal ring. What sits on the exhaust that need could do with a clean earth for its reference voltage?
11-01-2015, 10:31 PM
^^^ A very smart point, for better lambda readings perhaps?
11-01-2015, 10:43 PM
(11-01-2015, 10:31 PM)Dum-Dum Wrote: ^^^ A very smart point, for better lambda readings perhaps? It may improve reading. It could also be to stop electrical interference with the radio. Dont forget its like a 2.5m long bit of metal. It could act as an big ariel with any electrical noise from the engine
12-01-2015, 01:07 AM
Yep, for the lambda sensor, very bad ground reference otherwise.
Also the Lambda has a heater in it...
12-01-2015, 08:36 AM
Flip me.
I have been such a dumbass. I knew they have them, knew what it was immediately but tottaly forgot to put my earth on my exhaust and I am getting funny interference issues. I KNEW I made another short earth lead for a reason!! job for later... Wishes for more power...
12-01-2015, 08:44 AM
Ah that makes sense, didn't think about the lambda!
Do the diesels have them aswell if its for interference? Don't think I've ever seen one on a 306! |
