Threads: 87
48
I've hammered shit at it, had various straps and chains on it, access is a pig so doesn't help but I'm just squashing the filter, piggy, it's got bad laquar peel but its a straight car otherwise, exhaust needs welding or replacing, need the parking space back for my van which was elsewhere, needs to come home now though.
Threads: 23
Car Model/Spec: High Boost Rallye
Threads: 136
11
I had a similar problem a few years back on a berlingo.
Had to hammer and chisel the oil filter base off as it was soo stuck on. I had ripped the entire filter off trying to do the screw driver method . Took 30 mins of trying, to get it off
Threads: 28
Car Model/Spec: 306 1.8 Meridian
Screw driver, hammer, twist, done
Threads: 102
18
08-12-2014, 06:39 PM
(This post was last modified: 08-12-2014, 06:39 PM by RetroPug.)
If the filter is on tight enough due to someone overtightening it then the screwdriver will tear through the thin sheet metal casing instead of turning the filter.
The screwdriver method works for loose and maybe a marginally overtightened ones.
Try and get a decent long screwdriver onto the rim/lip of the filter as its much meatier...then thump it with a hammer
Threads: 110
20
Water pump grips will get the oil filter off. Some like these
http://pages.ebay.com/link/?nav=item.vie...0959499137
Threads: 29
Car Model/Spec: 306 2.0 8v Turbo
One way to do it if its still not moving, get a long chisel and hit the top of the oil filter lip to break the seal, i have done this as last resorts, but be very very careful.
1999 2.0 8v Turbo 306
You Tube: 832 Performance
Threads: 87
48
(11-12-2014, 03:54 PM)PUGNUT_XS Wrote: One way to do it if its still not moving, get a long chisel and hit the top of the oil filter lip to break the seal, i have done this as last resorts, but be very very careful.
it's going I haven't space anymore £150 will need towing, wanna buy it? lol
Threads: 29
(11-12-2014, 04:22 PM)Mattcheese31 Wrote: (11-12-2014, 03:54 PM)PUGNUT_XS Wrote: One way to do it if its still not moving, get a long chisel and hit the top of the oil filter lip to break the seal, i have done this as last resorts, but be very very careful.
I need a heated window switch LOL
Threads: 42
28
wont need towing, just someone to do the MTFUing and fit a new filterm
Threads: 87
48
12-12-2014, 09:59 AM
(12-12-2014, 09:51 AM)welshpug Wrote: wont need towing, just someone to do the MTFUing and fit a new filterm
yeah well, i could easily smash the fuk out of it, it's pretty mangled now as it stands lol, if you want to "mtfu" be my guest, i bought it for a quick flip and cba spending more time on it now, i won't lose any money . .
Threads: 29
Car Model/Spec: 309 grdt
If you wanted some muscle why didn't you just call me  ?
