	Threads: 14
Car Model/Spec: 306 1.6
		Hey got my 306 2 weeks ago its a 1997 1.6 , done 190k kms i live in menorca (spain), the car is from the mainland. ive tidied up bodywork exc, and i plan to get a sportex exhaust, 15" calibre motion 2 alloys and and deciding on what to do with the air filter. but 1st the engine is vibrating a lot when idling, and in turn the whole car and exhaust is moving. it is also sounding like a tractor and is down on power, now we thought it was to do with the exhaust which is blowing, but it seems to be many things. but from what i have read the idle sensor could need changing, and the engine mountings need checking, but that doesn't explain the lack of power and the noise. i don't have access to a ramp for a few weeks. so any ideas/advice is welcome.
		It sounds like it's misfiring?  That'll give you a rough noise and a lack of power.  It could be due to many things though!
Has it had a service recently, especially spark plugs?
If its idling at the right speed (800rpm ish when warm) and doesn't stall then the idle valve is probably ok.
	Threads: 206
Car Model/Spec: 3dr dt-s
		misfire; change the plugs, fit ngk .   if its still misfiring try leads and lastly a coil pack (most expensive item)
	Threads: 14
		leads all changed and plugs, fixed the acceleration problem, but the noise/vibration is the head gasket. 600euros.
	Threads: 14
		turns out its not the head, a valve had cracked.
