Threads: 1
04-11-2014, 10:21 PM
Looking at buying a 2001 HDI estate at the weekend and just wondered if there is anything in particular I should look for? Had a 306 before but the 1.9 D so hoping the
HDI has more power!
Speaking of power, any suggestions as to what basics I can do to ease more power out of it besides an air filter, de-cat and a remap?
Thanks in advance :-)
Rust in the rear arches, rear axle wear.
Smokey on start up.
Nasty noises from belts or bottom pulley.
You be amazed what a remap, deEGR and decat will do (leave the filter alone)...you'll have twice the 1.9D power!
Threads: 1
Do believe the bottom pulley has been changed as well as the cambelt, will be sure to check the other points you've raised though :-)
When you say de-egr, is that just simply disconnecting the wiring or fitting a blanking plate?
Will probably just re-new the air filter with a good quality OEM one if it's not sold by the time I get to go view it.
Threads: 1
04-11-2014, 10:44 PM
Sounds like a plan if the car is still available, if not then will just have to find another!
A fmic and uprated clutch maybe a little too much at the minute but something definitely to consider down the line.
Are there any minor handling mods that can be done? I know it's an estate but it's going to get a lot of use everyday
Thanks for your help btw
Threads: 1
04-11-2014, 10:52 PM
Haha I'm sure I could!
Cheers for your help again mate
81
Make sure there is an arch liner in the passenger side rear. If there isnt there will be a whole lot of rust up in the arch where the seat belt mounts. Look for ticking injectors and anything that is worryingly smokey or knocking. Check the rear beam for camber.
