	Threads: 9
Car Model/Spec: 306 hdi
		Hi wondering if anyone can help me, Ive been searching on this and google and is the bsi under the clock in the centre section or is the bsi the wee box the OBD plug connects to.
Its just the bsi and transponder chip that needs to be changed in order to use the different ecu?
	Threads: 169
91
		The BSI and ECU are locked together.
The BSI is under the clock in the centre section, accessed by removing the coin tray and ash tray, and then from under the dash.
If you want to change only your BSI and not ECU, then you will need to unlock your ecu.
![[Image: car-1.jpg]](http://i1117.photobucket.com/albums/k591/grant-306/car-1.jpg)
		Its actually a Body Systems interface and yes a PH3 306 does have one albeit it doesn't control much as iirc it was the first Peugeot with one, shortly followed by the 2002 onwards 206 and Partner which was fully CANBUS.
	Threads: 169
91
		So whats the black box in the same place on phase 2's?
	Threads: 42
28
		alarm ecu & transponder unit.
NOT a bsi.
		Alarm unit. Then you have the central locking unit in the rear quarter or under the rear seats
Peugeot list it as a BSI, its a BSI on PP and considering it is actually CANBUS (although this feature isn't used on the 306), the actual unit its self is a BSI. Its just a different software version on the unit.
	Threads: 42
28
		14-10-2014, 06:29 PM
(This post was last modified: 14-10-2014, 06:30 PM by welshpug.)
		specifically, part number 6580 18 CENTRAL LOCKING ECU
only found in HF central locking vehicles not the earlier IR plip systems.
not listed as a bsi.
