Waxoil
Waxoil
Does it really work and does it really kill rust and stops forming?
Waxoyl is awesome stuff. I unloaded (giggidty) 3 cans of it under my mini for winter running once and protected it lovely. Have used on an Austin 7 and an old triumph I used to look after as well with good effect. Both the standard and the black coloured ones both done the job well.
Waxoil is awesome stuff i personally cannot rate this product enough,i have used this product over the last 36 years on all of my cars that i have owned over the years,and is the no1 in rust proofing and it does what it says on the tin ThumbsUp
Can you just spray the whole underside?
Yeah. The whole lot. Ive got an underseal that incorporates waxoyl though for job like that. Hammerite and waxoyl underseal its called.
I've used it on brake lines before...coincidently around MOT time...I'll get a few more tins and just rattle the whole underside when it dries up a bit!
Ye its good stuff I sealed my Merc with it , let the can sit in some hot water for 10 minutes before you use it thins the wax down & makes it easier to spray & blast it into all the box sections you can get & let it run down inside the box section
Tis very good stuff.
