Threads: 5
Car Model/Spec: 306 LX D
'evening all,
I finally had the chance to sort the rear brakes out, all apart from this type of circlip.
I was a little hesitant to use force as I didn't want to stuff the new bearing.
How do I get the damn thing in without knackering the bearing, losing fingers or swearing?
(apologies for crappy picture quality)
Threads: 371
29
Car Model/Spec: ford fiesta
Just push it in with hand untill its in then tap it down with screwdriverpunch hammer
Threads: 5
I got it down to the rim half way down but as one end went down the other came up.
I thought about using a socket but wondered if I could compress it somehow?
Threads: 371
29
Just get a friend to hold one side down as you tap other should be easy never had an issue with them before
23-07-2014, 08:48 AM
(This post was last modified: 23-07-2014, 08:48 AM by Toms306.)
You cant use circlip pliers on those without the holes...
I haven't had an issue with fitting these though, they literally just push in! Push one side right down, hold it there and then push the ends in...
Threads: 5
Well, I feel a bit of an idiot
Thank you BashBarnard and Toms306. After a fresh look at things, the clips went in soft as butter.
All I can think is I was just tired and couldn't see the most straight forward way of doing it.
Threads: 371
29
Ive been there before to tierd to to do anything logically
